Recording takes 5 seconds to start !
We have Pro Tool 7.4 HD , when clicking on the recording button from the keyboard, it takes 5 seconds to start the recording, whereas previously it was instantly . Is there a setting for this ? what should we check ? |
Re: Recording takes 5 seconds to start !
Just go to the preferences and in " handy features" untick the " take 5 seconds to record " button, or, check the drive isn't fragmented and that maximum record time allocation is set at a sensible amount
that was good one...
also, check that count off isn't on or pre roll. b.o.l. e
ihatetyping |
I can not find the hand features in preferences. please check this snapshot : http://img710.imageshack.us/img710/6...reference2.jpg are you talking about the Back/Forward Amount option ? or there is anothe option under another tab and regarding the "maximum record time allocation is set at a sensible amount" where is this option ? under which tab ? |
Also would appreciate if you can give me step, like where can i find this option ? |
In the transport window, check to see if pre roll or countoff is enabled. If you're having problems finding where this is at, check out the Pro Tools manual, specifically page 376 on setting pre roll. You could also try changing your record allocation to 15 minutes to see if that helps.
https://www.thirdeyerecording.com/ |
It's called "Open Ended Record Allocation" and set it to 10 minutes unless you need to record longer.
Rail
Its currently set to Use All Available Space, i have tried to set it even 5 minutes, but still the delay is the same !
If the Open Ended Allocation doesn't help then your DAE buffer setting is too high - set it to the default of 2
Rail
Transport takes 5 seconds to actually start | bunderson | Pro Tools M-Powered (Win) | 1 | 07-15-2008 08:29 AM |
PT delays everytime i start recording (about 4 seconds) | mbauer1 | Pro Tools TDM Systems (Mac) | 3 | 11-17-2007 07:16 PM |
It takes 40 secs to start recording..Please help!! | Camilo Toledo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-12-2003 06:02 PM |
001 recording start takes forever | jtrolka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-29-2003 12:57 AM |
Takes time to start recording | Duh! | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-10-2000 08:42 PM |
