8 ch output from FCP
I'm building a Final Cut Pro editing suite, with a Kona 3 card. Which is going to be the better solution for monitoring 5.1 audio out of FCP? 1. ProTools 003 using the sound manager, or 2. an external converter like a Apogee Rosetta 800 hooked up to the Kona 3 AES outputs? I like the idea of a PT 003 system, so at least there would be a Native PT system online.
Thanks, STeve
macmandigital.com |
Re: 8 ch output from FCP
I'm doing the same, but using a Black Magic Multibridge... coming out the 25 pin AES to Apogee 800 for conversion. Haven't hooked it up yet... Apogee still in the box. I never considered an 003... how do you get 8 channel of AES into an 003? Through core audio?
Then there's the firewire delay to deal with. Consider using Audio and video out of the same box to try and limit the sync issues. |
STeve
macmandigital.com |
STeve
macmandigital.com |
I'm not sure while running PT it would like the Kona card installed. FCP>Digicoreaudio>003> speakers would probably work, but when starting PT, it might not like the Kona being there.
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). | Focuret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-12-2014 07:33 AM |
Fast track pro: signal on output 2 while output level at 0 | sbrunot | FireWire & USB Audio Interfaces (Mac) | 1 | 12-26-2013 04:11 PM |
Whats the Difference between Bounce to Disk Source -> Physical Output vs -> Output | Epik Productions | Pro Tools TDM Systems (Mac) | 8 | 05-03-2013 12:48 PM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
No output to 1622 *and* master fader shows output? | nettwerk | Pro Tools TDM Systems (Mac) | 1 | 10-30-2000 05:35 AM |
