why doesn\'t analog factory show up on my instrument list?
When i'm in pro tools and insert a instrument on a instrument track it never shows up. All the other plugins that i installed show up but that particular one doesn't then when i go to the plugins folder i see that it's installed with the other plugins.
Re: why doesn\'t analog factory show up on my instrument list
It would be much easier to help you if you posted details about your setup. You don't even mention if you're using a mac or a PC, let alone which version of PT you are using.
I'm running pro tools 7.3 with windows xp.
Have u looked under mono and stereo tracks? and Restarted Pt since the install...
yep/
Re: why doesn\'t analog factory show up on my instrument list?
From Arturia's site:
Q: My plugin does not work in Protools. However, the standalone version works fine. What can I do? A: First of all, verify that files : - [Windows] "Analog Factory.dpm" and "Analog Factory.dpm.rsr" are correctly installed in "C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins". - [Macintosh] "Analog Factory.dpm" is correctly installed in "/Library/Applications Support/Digidesign/Plug-Ins/". Check that only the latest version of the plugin is available in this folder, and that you don't have any 'arturia engine' in your plugin folder. If the dpm files are not present, try to re-install the application from the last update installer you have downloaded (or from the CD-Rom). It is highly recommended to use the last update since it is more stable. Launch protools, create a stereo audio track and look for the plugin in "multi-channel plugin > Instrument". If the plugin still does not appear in the instrument list, and you are on a Windows platform, you might miss some required Microsoft libraries. These libraries can be installed easily using a Microsoft program "vcredist_x86.exe" that can be found on Microsoft website: http://www.microso ft.com/downloads/details.aspx?displaylang=en&FamilyID=32BC1BEE-A3F9-4C13-9C99-220B62A191EE Download and install it. It should fix the problem.
Link seems to be malformed
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
002R analog ins 5 & 6 don't show up in PT 8.03 | tooold | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-24-2010 02:33 AM |
Strike! doesn't show up in instrument trk. | kevjones810 | Tips & Tricks | 3 | 02-26-2009 06:28 AM |
Xpand does not show up in the list | attilaworx | Virtual Instruments | 1 | 11-28-2006 11:24 AM |
Help: Can't get analog 9-16 to show up for AD16X | jjblair | Pro Tools TDM Systems (Mac) | 1 | 11-19-2005 07:50 PM |
Show/HideTrack list bug 6.7 | shadowbox | Pro Tools TDM Systems (Mac) | 3 | 02-07-2005 05:09 AM |
