main outs vs. others
i just changed some things around in the studio and in doing so I thought i would
hook my cd burner directly into the 001 main outs and see what the outcome was.... DISTORTION!!! Same track sounds great out of the mackies, and great if I run the outs into another mixer and analog to the cd burner. (this is my norm) Which jacks are best for final output to cd burner directly out of the 001?
TAKE IT EASY! IF IT IS EASY, TAKE IT TWICE! IF IT IS STILL EASY, BEWARE!! |
Re: main outs vs. others
best results would be to be able to use the spdif outs ot a burner, but I am assuming you have a burner with analog inputs only. I'm also assuming you have a burner with no input metering, otherwise you would have seen it being driven past digital zero.
Try any of the 3-8 op, as they are unbalanced -10db, vs the 1/2 op which are +4db balanced. Again I'm assuming your analog inputs to teh burner are probably -10db rca connections.... |
where o where are you tonight?
thanks for the input and your assumptions are right except that i do have a led read out on the burner and that is what started my question. The old way of burning my record input on the burner was @ zero or -1 db. The new setup my burner is input is @ -15. Sounds like it is just the difference in the balancing and cutoff of the jack! thanks again
Digi002 rack main outs vs monitor outs | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-03-2012 07:46 AM |
Main Outs | dmock66 | Eleven Rack | 13 | 06-03-2011 01:27 PM |
Problem with 002 main outs as well as head phone outs? | wiseal1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-10-2009 11:36 AM |
001.....Main Outs or Monitor Outs | G. Klopfenstein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-01-2004 08:07 PM |
How can I have the monitor outs and main outs to the same input? | voxpitch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-15-2001 09:16 AM |
