Eucontrol Settings Shortcut?
Hi, I have the Avid Artist series (3 mixes and 1 Control) and I have the entire surface locked to the Pro Tools application. If I press the shift soft key in the lower left/right of the Control surface and press the ASSIGN/ SEL button to the left of the fader, it opens Eucontrol Settings. Is this normal behavior? Can this be disabled?
Re: Eucontrol Settings Shortcut?
This is a feature (believe it or not, I had to RTFM) so you can quickly assign tracks.
Ok sounds good. Really quick what’s the fastest way to select/fade a clip from the Artist Control
I'll have to pass on that question...not sure there is a quick way.
Ok thank you
Check that “edit selection follow scrub/shuttle” and “link track and edit selection” is enabled. Create a softkey for fade in or out. Scrub to the fade start or end. Select the track containing the clip. Tap on the softkey.
EuControl settings | micheallsmith | Artist Series | 4 | 03-01-2016 06:19 PM |
eucontrol settings | Phili | Artist Series | 0 | 02-28-2012 03:31 AM |
Pro tools click settings (1/8 notes or 16th note settings )? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2008 09:59 PM |
Cannot save plug-in settings to Root Settings folder | SimonORorke | Pro Tools M-Powered (Win) | 1 | 01-18-2008 08:38 PM |
Shortcut for Copying Bus settings in edit window... | BearClaw | Tips & Tricks | 9 | 07-26-2001 05:34 AM |
