RELINKING MISSING FILES
Have had a bad accident ... had lost about 60 GB of AIFFs and session data. My query is simple .. my data has been recovered by data rescue ... but the software has completely renamed the files to its own convenience, unfortunately ...
If I open a protools session ... is it possible that protools can find some kind of a signature like space or digital ID or something such that it relinks old files altogether??? If not ... what are the other options available to restore the session data as it is ... ??? Please help Yours, Sid |
Re: RELINKING MISSING FILES
PT will present the options to you when you go to relink. Once you actually try it, it should be self-explanatory.
not so ... the data it must search from is nearly 67 GB ... all it does is performs the search ... i waited for a dozen of hours
Now what can I do? Sid |
You use the link window to scale down the search area via the file tree, point it toward the folder where you know the files are. You can change the criteria for finding find links somewhere in there too, I'm not in front of my system at the moment so I don't remember exactly where. So change the link criteria then show it where to search and see if it can find anything. It may not be able to depending on the shape of the files, but that's how you'll go about finding out.
Missing files, Relinking, Select the files... | Kdose | macOS | 0 | 02-27-2014 09:53 PM |
RELINKING MISSING FILES | Siddhant Bhatia | Tips & Tricks | 0 | 04-27-2007 05:53 AM |
7.2 missing files / relinking / HELP !!! | Aquarius | Pro Tools TDM Systems (Mac) | 5 | 09-07-2006 04:35 AM |
missing audio files relinking... | Alex Rodriguez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2006 04:59 PM |
relinking missing regions??? | lightning ad | Post - Surround - Video | 5 | 03-15-2006 08:38 AM |
