Digimax LT using internal clock?
Hey there everyone, I just got handed a mix that was recorded with the internal clock, and I have the presonus digimaxLT that I use as my pre-amp. How do I get it to be record enabled and not pop without changing the clock to ADAT? Because when I do that, the song speeds up tremendously. Do I need to push "Ext. Clock" on the digimax, change the sample rate, anything? Thank-you so much!!
bret
PT LE v8.0 digi 002R digimax lt PowerPC G5 dual 2.0gz 7 gigs ram 2 TB HD Tannoy Monitors Yamaha NS-10 |
Re: Digimax LT using internal clock?
Digimax LT has only ADAT output, so the only way to get clock into the box would be the Wordclock I/O, which you do not have in your 002R. The workaround would be to use some box that has SPDIF I/O and Wordclock I/O to get the internal clock out of the 002R via SPDIF I/O and then feed it to Digimax LT via Wordclock I/O. So you're better off by just clocking to Digimax LT via ADAT. Quote:
So if you clock to ADAT, you have to set correct sampling rate to Digimax LT manually. Just think what you're doing and it's going to be allright.
Clock Problem with Digimax FS | fooloof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-27-2010 07:14 PM |
OO3, Digimax D8, Which Better As Clock Master? | taylor4814 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-11-2009 09:13 AM |
Dbx386 s/pdif clock VS. Digi002 internal clock | Detuned6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-02-2006 09:32 AM |
192 I/O Internal Clock or SYNC Unit Clock? (is there a big difference?) | Mastersonics | Pro Tools TDM Systems (Mac) | 0 | 04-18-2003 07:14 AM |
192i/o Internal Clock vs. Other External Clock | everglass | Pro Tools TDM Systems (Mac) | 1 | 08-27-2002 08:51 AM |
