Old 01-23-2007, 06:25 AM
Tommy Fobia Tommy Fobia is offline
Default Mbox 2, \"Pro-tools has closed unexpectedly\"
Hi, I'm running an MBox 2 with an intel macbook 1.83 core duo with 2gb of kingston ram. I have osx 10.4.8 and PTLE 7.1.1cs.
It is horribly unstable. I occasionally get pops/clicks etc, but more often than not, protools just decides to quit every 40 minutes or so. I have played around with the playback engine settings to no avail. Any ideas? I'm getting extremely frustrated!
Thanks for your time.
Old 01-23-2007, 08:40 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Mbox 2, \"Pro-tools has closed unexpectedly\"
Are you recording to an external drive?
Also, check to see if you have the correct version of plugs. See:
http://www.digidesign.com/index.cfm?...n=news_details
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-23-2007, 03:16 PM
Thanks for your reply!
I've had a look through that plug-in list and everything seems to be up to date/compatible, but good suggestion anyway!
I'm running a Lacie D2 firewire 400 as my audio drive.
I've noticed that things become much more unstable if I have processer hungry plug-ins running, such as toontrack EZ-Drummer (which is up to date) or multiple 7-band EQ3s running on separate tracks. This is strange as the processor can be peaking at less than 30% of its maximum. I've tried this with both processors and a single processor and experience the same problems.
I have two gigs of (Apple approved) Kingston KTA-mb667/1g...
I really am stumped with this one...
Any help or suggestions would be much appreciated.
Old 01-25-2007, 05:14 PM
Sorry to bump my own thread, but protools is extremely unstable and its incredibly frustrating.
Has anyone got any idea why?
Audio is streaming fine of the external lacie D2 fine. Problems only seem to occur when I use processor hungry plug-ins, so I guess it has something to do with pro-tools and mac-intel setups.
Ok, another question that someone may be able to answer:
Is PT 7.1.1cs 100% compatible with intel core duo (not core2duo) processors?
Thanks for your time, Hopefully you can help me have my first stable session!
No Sound when Pro Tools Closed. iamtall Windows 1 06-26-2012 04:19 AM
Mbox 2 microphone signal is audible though Pro Tools is closed brandonl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-06-2010 12:50 PM
Using WaveDriver - Pro Tools Must Be Closed? taylor4814 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-25-2010 07:34 AM
Pro Tools LE with Mbox "unexpectedly quits" REV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-05-2004 08:19 AM
Pro Tools crashes PC when closed!! och Digidesign Hardware & Software 1 09-05-2002 04:43 AM
