LE does not launch
PT Le 7.1.1 is not opening anymore, It bounce a couple of time in the dash board but it wont launch. I v tried to uninstall and reinstall (nothing), I have download again from Digi and I v install it again freshly (noting), I v repaired permission and all that...it doesn't want to launch... Any suggestion ? I m kind of desperate , it really drive me crazy.. thanx a lot |
Re: PT Le do not launch
We need a lot more information. See the sticky threads at the top of this subforum.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
PS
here my spec. : MPB 15" - 2GB Ram -2.16 Ghz Mac OS X 10.4.11 M-box original Pt LE 7.1.1 before my M-audio firewire 410 breake down I was using both PT M-Powered 7.1.1 with the FW 410 plus PT Le with the M-box. Now I have unistalled both M-audio soft and driver and I m trying to use only the Mbox with PT LE 7.1.1 |
This sounds like the issue of updating the OS via Apple's "Software Update" feature. As a long time Protools users, I've experienced this before. It is recommended that you do not use the "Software Update" from the Apple dropdown menu as a way to update the OS (other updates seem to be fine). The proper way is to go to www.apple.com and download the "Combo Update" for the OS version you are upgrading to (even minor releases). This uses a larger update file that seem to work much better than the smaller one used in "Software Update."
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
thanx dragon,
so any suggestion to solve the issue ? I would try to avoid to reinstall OS X 10.4.11 combo again.... |
I would uninstall and re-install - but before you reinstall, make sure that ALL PT files have been properly erased. Easy on a Mac by searching for keywords "Protools" "Digidesign." Non erased files can cause problems.
Peter. |
I m so desperate that I m almost ready to reinstall all the OS X... what a pain tough....If there is any other suggestion would be great. cheers By the way I v downloaded and tried to install also Ptle Cs2 but this what is coming out: ptle 711-31546 dm not recognized... what this means? |
No no no. You need to reinstall the "Combo" update for the OS by manually downloading it from the Apple website. What you need to avoid is the "Software Update" from the Apple icon on the menu bar.
Obsidian Dragon
Pt is still dead... |
so no idea on this matter?
I do not know what to try next... |
pt 8 won't launch | creeper59 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-07-2009 02:27 PM |
PT LE don't launch | pouépoué | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-07-2007 12:52 PM |
Can't Launch PT | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-24-2007 05:05 PM |
PT won't launch | mattshort | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-28-2005 09:51 AM |
PT 6.9 won`t launch 6.7 will launch-FCP5 problem? | yoursickstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-30-2005 05:10 AM |
