Apogee DA-AD 16X as hardware inserts - small timing probs?
I’m thinking of buying a HD Accel HD2 or HD3 rig in the near future... to use with my Mac Pro.
I’m probably going to buy ad da 16X Apogee converters, (and X-HD cards) and not a Digi 192. (don’t try to talk me out of using Apogee - as I like Apogee stuff a lot... my only other option would be to also buy a Digi 192 just to have a fairly fail-safe interface always on hand - in terms of possible software upgrades and possible temporary incompatibilities.) So - my understanding is that the actual converter timing of Apogee’s 16X series of converters is slightly different than the Digi 192 interfaces. I’d love to be able to turn on delay compensation within ProTools, and then send aux sends and auxes to run out to analog compressors, then back in on aux inputs, to do parallel drum compression. I’d also love to be able to insert analog EQ and analog compressors across some tracks. My concern is that this may prove to be problematic.... due to it not being +/-1 sample. I’d like things to remain in phase as much as possible.... and not have to deal with time adjuster plugs, or shifting tracks. Also - I understand that the AD/DA 16x appear in a slightly odd configuration in the I/O setup. Will this prove to be a pain at all, and how will my desire to do inserts and parallel compression work? Thanks for any advice or tips. |
Re: Apogee DA-AD 16X as hardware inserts - small timing prob
go for the apogees! i´am using them and everyting works (and sounds) fine!! and you don´t need to purchase a 192. in case of analog inserts this will be interesting if you don´t already read it:
http://www.apogeedigital.com/support/adcalc.php and heres another thread on this... http://duc.digidesign.com/showflat.p...rt=&PHPSESSID= hope that helps! cheers, alex |
aha!
thanks for the awesome info much appreciated cheers |
the plot thickens...
so what if I have a bunch of audio tracks, and I have an aux send on all of them, and I send varous amounts from these tracks, then I route that aux send buss to an aux in, and do a hardware insert across that aux in..... and i'm using an Apogee interface with X-HD card (nort a digi 192) and across that aux in I insert an analog compressor, then I want to mix that compressed signal back in (from the aux in) with my mix (thus being parallel compression).... won't it be a problem? As the timing of the Apogee converters is different than what it thinks is there.... Any easy and smart workarounds? I'd prefer to buy Apogee converters and an X-HD card, and not have to buy a Digi 192 (as the ability for the Apogee converters to be used standalone would have some advantages for me) thanks |
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
PT9 Apogee Inserts I/O mappings problem | no-xplode | Pro Tools 9 | 2 | 04-11-2011 01:56 AM |
Small db loss between inserts and track fader | SupMe | Pro Tools M-Powered (Mac) | 5 | 11-03-2007 01:34 AM |
Apogee AD16X 192 help Apogee not seen in hardware manager | assemblyworker | Pro Tools TDM Systems (Mac) | 4 | 04-19-2007 02:20 AM |
Anyone Else have Probs. with Digimas Inserts? | Matt Whritenour | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-18-2004 07:59 PM |
