Uninstall Digi CoreAudio driver?
Does anybody know a way to uninstall the Digi CoreAudio Driver without having to do a full
uninstall/reinstall of Pro Tools. Is there some Library file I can just remove. I am running PT HD 7.1. thanks in advance... |
Re: Uninstall Digi CoreAudio driver?
If you are trying to get something to work without the driver installed, you don't have to completely trash it.
Move it to your desktop or even another drive in a backup folder. I don't believe the system will see it if it's not in the correct folder. I had a lot of luck when setting up an MBox. You can move it around temporarily. |
but I assume there is a library file somewhere else and I can't find it. |
Sorry, I meant the app. Just move it out of the digi folder.
The driver is part of the app contents. I may have read something about it needing to remain in the digi folder on the answerbase. |
OK, I apparently managed to stump the DUC with my question, but I just did a google search on
"removing coreaudio drivers" and found the answer on Digi's site. Thank you Google for indexing digidesign.com! From http://www.digidesign.com/index.cfm?...00&itemid=4877 ++++++++++++++++++++++++++++++++++++++++++++++++ Removing the Digidesign CoreAudio Driver v7.0 To uninstall the Digidesign CoreAudio Driver: * From the link below, download and expand the Digidesign CoreAudio 7.0 installer * Double-click on the Install CoreAudio file. * From the pop-up menu, change Easy Install to Uninstall * Click the uninstall button to remove Digidesign CoreAudio files from your computer To manually uninstall, remove the "Digidesign CoreAudio.plugin" file from the following location on your hard drive: Library/Audio/Plug-Ins/HAL |
Uninstall Digi CoreAudio Manager | _fiver | General Discussion | 1 | 07-10-2013 06:29 AM |
digi CoreAudio driver still supports 8 i/o only. Why? | Tobias Eichelberg | Pro Tools TDM Systems (Mac) | 2 | 01-03-2009 02:03 PM |
How to uninstall standalone digi coreaudio manager | Ben Jenssen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-02-2007 08:31 AM |
Digi Core Audio Driver Uninstall ? | TCLguy1 | Pro Tools TDM Systems (Mac) | 2 | 02-05-2006 08:12 PM |
Digi: What Benifit's are to Coreaudio Driver 6.7 ? | SoundEng1 | Pro Tools TDM Systems (Mac) | 1 | 11-15-2004 07:59 PM |
