midi selections in midi editor with piano roll
when I open a midi region in pro tools 8.1 by double clicking on it in the edit window the midi editor opens. as it is a region containing midi notes to trigger strike VI I only want to modify the notes for the hihat in that particular region... when I use the piano roll by clicking the specific key to select only the hihat midi notes in that region I opened the hihat midi notes of the entire TRACK become selected which is not what I wanted. what am I doing wrong ? any help is highly appreciated
Re: midi selections in midi editor with piano roll
That is by design.
Aaron Mulqueen - 001 HD Native |
thanks filosofem ! that is what I feared. hopefully it will get fixed in a future update like pro tools 8.2 ! it makes no sense to me when I want to work on a specific region and want to select notes fast IN THAT REGION by clicking on the piano roll in midi editor the notes of the ENTIRE TRACK become selected. AVID please fix ! the only workaround would be to lock every midi region I want to keep away from incidently editing like locking an audio region. I hope this is possible. anyway thanks again filosofem for your comment and all your other statements, hints and advices here. they are and were very helpful to me and I guess to many other users too.
I can understand your frustration but there are many uses that prefer that mode of operation. Perhaps you could change the way you work by splitting the drum track in separate instruments per track.
to me it seems more logical selecting and editing a note from the piano roll in a specific region in midi editor should affect only notes in that region... you have a piano roll in the edit window as well... editing the entire track should be done from that roll...
to all interested in my midi madness: I just tried to solve my problem by locking midi regions on a track I do not want to be edited: PT8.1 reacts as follows: a warning pop up window appears saying: *you are going to edit parts of locked regions, proceed?* if I click yes I am where I have been if I select cancel everything stays the same. here I go *shift click* again... tiresome...
Is there a key command to bring the new piano roll editor pane up? | Ru_C | Pro Tools TDM Systems (Mac) | 2 | 03-14-2011 11:04 PM |
MIDI Piano Roll "Greys Out" | bugnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 35 | 08-19-2009 01:03 PM |
MIDI Editor Piano Roll New Feature! | Mason00 | MIDI | 4 | 04-13-2009 04:06 PM |
piano roll in midi track | pietervd | Tips & Tricks | 2 | 02-24-2006 07:10 PM |
Insert MIDI notes w/ mouse on 001 piano roll | scuppari | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-20-2003 09:01 AM |
