Old 01-25-2005, 06:47 AM
legitmik legitmik is offline
Default DAE error 9131
emac/ 10.3.5 /Protools LE 6.4 / MBox
I'm running 2 Lacie D2 firewire drives (one portable, one for backup). When I try to edit a session on the backup drive it tells me that the disk allocation has changed from the previous session. All well and good since the file I'm opening and the associated audio has been copied from the one in the studio. However, when I try to play back the tracks I get DAE error msg 9131. Why should it give an error message having reallocated the audio?
Having looked at the Digi answerbase it gives reference to the problem but tells me to reformat my drive. Bit hardcore that.
Any other suggestions?
BTW, has anyone experienced any problems with the D2 drives? I'm always getting 'Alternate header block problem' when I run Norton on it. Is this something to do with going between 8.6, 9.2 and 10.x?
Cheers
Mik
'Yer ideas are bigger than yer budget'.
Old 01-25-2005, 07:18 AM
Brent Flash Brent Flash is offline
Default Re: DAE error 9131
One problem could be the use of Norton. If you visit the Apple forums they will be a little more direct and say Norton is death for OSX. I have to admit that since I have stopped using Norton I have had less problems.
DAE error -9131. What does this mean? splyman Storage Subsystems 5 01-07-2016 11:30 PM
-9131 error cellopiano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-08-2010 06:10 PM
DAE Error -9131.... Yes, the dreaded -9131. defconnect5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 08-06-2006 06:54 AM
DAE -9131 Error phildone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2005 08:24 AM
error 9131 The Count 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-29-2004 01:19 AM
