Old 05-28-2021, 09:51 AM
quangaroo quangaroo is offline
Default Export vs Bounce Gain Levels
I do very straightforward voiceover recording in Pro Tools. Almost always single tracks, less than 3 minutes, all voice, and no plugins (no music).
I've found when creating mp3's I will sometimes get a file whose mp3 sounds louder when I bounce it, than when I export it as a region.
And sometimes when I'm adjusting the gain levels on a region, every time I export it, it sounds the same, but when I bounce it, it now sounds louder on playback.
Any idea what I'm overlooking or doing incorrectly that would make this happen? Thanks!
Mac Pro 5,1 (Mid 2012) | macOS 10.13.6 | 48GB RAM // Pro Tools 2019.5.0 | Digi 003 Rack | Digi 003 Rack+
Old 05-28-2021, 04:40 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Export vs Bounce Gain Levels
Export does not include any volume automation, you are just exporting the file "as is", exactly as if you copied the file from the Audio Folder. Bouncing out includes any volume automation.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-31-2021, 08:06 AM
Export also does not keep any plugin processing. It simply exports the raw audio file that is on the track. Another option would be to commit the track(which will render all the plugin processing) and export the resulting audio.
Setting gain levels for VIs and such DonaldM Avid Pro Mixing General Discussion 2 01-31-2019 10:42 AM
Gain Levels nexty76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-27-2011 05:26 AM
Microphone levels too low - need more gain gagard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-19-2004 10:01 PM
Gain Levels...recording StainedClass Pro Tools TDM Systems (Mac) 65 03-28-2003 09:11 AM
Mastering and gain levels surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-21-2002 12:29 AM
