A/D conversion
Is there a big difference in audio quality between aes/ebu and s/pdif? How are we 002 users supposed to get high quality digital audio in to pt other than adat. High res, 96k. Right now I'm useing adat ins(at 48k)for drum set. And analog for instruments and such. I want to get a fairly good stereo preamp (amek, ua, true, something under $2000). And an a/d box(ua 2192) for the s/pdif in. Is the signal degraded by useing the s/dif input? We don't get aes inputs.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
Re: A/D conversion
Think about getting a 8 channel preamp with optical output. Then you can make use of the other 8 ports. Optical is digtital already, so no more conversions all the way into your session
Share the gift gifted to you |
Re: A/D conversion
And as far as the 8 channels (Digimax, etc...) units, compare them to the UA610 throug hthe 2192 and see which one you think sounds better. -S0nguy |
Re: A/D conversion
I'm already useing a digimax 96. read my first post. I'm trying to decide on another ad converter. something with better converters than my 002r. Also better preamps.
Re: A/D conversion
Spdif and AES/EBU are basically the same. AES/EBU is balanced and therefore capable of longer cable runs.
Re: A/D conversion
You're right, AES/EBU and SPDIF are "basically the same". However, more attention should be paid to the type of cable and connectors used. SPDIF is inherently more susceptible to jitter than AES/EBU...but this really doesn't matter if you pay attention to the cable, connectors, and cable lengths in your setup.
Cavell Studios |
Re: A/D conversion
that's cool guys thanks for the replies. cable length is not a problem in my 12x24 home studio. All of my equipment is at the same end of the room. I just wanted to make the best choice.
Re: A/D conversion
-S0nguy |
MP3 conversion | xfbt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-08-2007 02:40 PM |
OMF conversion in pt7,2 ? | supafuzz | Pro Tools TDM Systems (Mac) | 1 | 01-17-2007 10:44 AM |
7.x to 6.x conversion | Mixstuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-12-2006 07:34 PM |
A/D conversion...which is the best way to do it? | trackfive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-06-2002 12:54 AM |
MP3 conversion | devee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-27-2000 02:03 PM |
