#21
Re: 2021 and still no sidechain latency compensation..
The only solid work around for me is freezing the instrument track or committing it to audio. Which, of course, is a total workflow killer, because if I want to rearrange a part I have to unfreeze the instrument track or make the initial track off which I committed active again to edit some midi notes.
The 'disable plugin delay' function does seem to have side-chaining in sync, but this introduces other problems with the midi notes itself getting out of time. I created a support ticket about this last week, after years of struggling with this issue. I even wonder if a HDX system would tackle this issue. Quote:
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3 |
#22
Have a (hopeful) update. I submitted a formal case about this issue to Avid support, as an active support patron, about 2 months ago. Should have done this years ago. They finally got back to me a couple weeks ago, apologizing for the delay and attributing it to a large influx of support cases they'd recently received.
They asked me to send an actual video recreating the problem, so I obliged. I had to check in a few times to make sure someone accessed and downloaded the video and my extensive notes describing the problem and explaining my recreation of it. I used a very simple session with just two audio tracks to illustrate the issue, hoping that would make it abundantly clear that this is a very base-level issue with the software and not the result of some overly complicated session with bonkers routings. This is the response I got from Avid support yesterday: "I got word from the Engineering Department that this issue was a legit bug and it will be fixed in the next update of Pro Tools." Now, I'm not quite sure how seriously to take this reply yet, but if it's true...?!! Goodness oh me, will I be extremely happy if they are actually planning to roll out the fix for this horrible issue in the next PT release. I'm remaining cautiously optimistic since the first response to my case was that there was "no definite timeframe when it will get a fix," but then changing to the response above when I checked in with them about my video. But I can hope. Just wanted to share what I heard.
Mac Pro 3.5GHz 6-core (6.1, "trash can") Monterey 12.7.3 32 GB RAM Pro Tools|Ultimate 2023.12 HD Native Thunderbolt HD I/O 16x16 Analog |
#23
I want to believe.
#24
Well maybe this is part of the Hybrid Engine that is coming out in June. If sidechain compensation has only been available to the premium customers (HDX users) so far and there is now the opportunity for HDX users to switch between DSP or native per channel with the lightening bolt button, it would be very clunky to have sidechain compensation work if you click the button (DSP) but broken if you deselect (Native). The Hybrid engine might make sidechain compensation easy to implement.
If this is the case then hopefully Avid would not decide to make sidechain compensation work natively only if you are a HDX user. That would be very provocative.
Simon2065 Pro Tools Ultimate 2023.12 Win 10 Pro 22H2 Gigabyte GA-Z270 i7-7700K 32GB Ram UAD Apollo 8 |
#25
I did one and got "are you still experiencing this problem?" Completely useless.
#26
keep submitting those cases. Keep submitting. Keep submitting.
#27
See this thread http://duc.avid.com/showthread.php?t...ight=sidechain
Question is whether Avid allows sidechain compensation to work natively only for HDX users or allows for non-HDX users as well.
#28
For Protools 2021.6:
Automatic Delay Compensation On Side Chains Until now, Automatic Delay Compensation on Side Chains has been only available on Pro Tools HDX. With Pro Tools 2021.6, it is now available on all Pro Tools systems. This is a consequence of the necessary convergence between Native and HDX systems which the Hybrid Engine employs. To maintain consistent ADC performance with the Hybrid engine for HDX users, side chain delay compensation had to come to native systems. If side chain ADC didn’t work natively it would have been necessary to keep side chained tracks in DSP mode just to maintain the delay compensation, which wouldn’t have been an efficient use of DSP. That being said it also addresses a longstanding issue for native users.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
#29
Check out avid.com/resource-center/whats-new-in-pro-tools?video=48380acb-0164-4078-bf00-108ca2ffe7d1 on the What's New in Pro Tools page.
• linkedin •
#30
Is the side chain lag compensation working properly? Has anyone tested it?
And what about older sessions where the sidecain is adjusted manually? |
HDX Sidechain Delay Compensation Broken? | Drywsef | Pro Tools 2020 | 6 | 03-18-2021 07:10 AM |
Commit and Sidechain Delay Compensation | Glo123 | Pro Tools 2020 | 0 | 01-09-2021 11:25 PM |
Sidechain Delay Compensation | JingleDjango | Pro Tools 2020 | 6 | 06-17-2020 06:02 PM |
Workaround for sidechain delay compensation? | DJ Hellfire | Pro Tools 12 | 8 | 07-15-2017 09:37 PM |
Sidechain latency workaround! | Appehl | Pro Tools 12 | 0 | 01-02-2016 06:08 AM |
