Old 11-15-2003, 03:16 AM
clouvel clouvel is offline
Default Panther: Good Bye Digi !!
Just read compatibility information :
Digi says good bye to Panther on powerMac G4 and power Mac G3 !!
Ok I say good bye Digi
tchaoo
au revoir
Digi for me, it's the end.
Old 11-15-2003, 03:22 AM
dubaifox dubaifox is offline
Default Re: Panther: Good Bye Digi !!
Whaddya mean? Is this new info? They have been saying compatibility with newer G4's. Yes, not to G3's but let's get serious, those are old machine and have completely different innards than G5's. I'd be bummed though if there was no G4 support completely. Where did you see this?
International Award Winning Arabic Fusion
www.ajmusiconline.com
2xMacPro 2.66,002r,OSX 10.4.10,PT 7.4cs8
3xVisionDaw,NI Komplete,Yamaha 01V/96
Old 11-15-2003, 03:25 AM
stoogee stoogee is offline
you have to be joking, my Panther is sitting here unused.
SG
Old 11-15-2003, 03:42 AM
Hmmmm.
I see new what you are saying. The new post from the technical administrator, says that G4 support is no longer in there three phase process, but will be supported in a further phase (read never) But only 866 MGZ computers and faster.
So it is a change in their earlier position where they said G4 support was in Phase III. I think.
you can read :
expected November 21, 2003 :
- Digi 002, Digi 002 Rack, Mbox on Mac OS X 10.3.1 only
- On the following computers: Power Mac G5 1.6 GHz, 1.8 GHz, and Dual 2.0 GHz models; iMac G4, PowerBook G4, iBook G4.
and :
The following items fall outside of the scope of the above Phase I, II, and III qualification :
- Pro Tools|HD and HD|Accel with Power Mac G4, 733 MHz and faster, with Mac OS X 10.3.1
- Pro Tools|24 MIX Systems with Power Mac G5, with Mac OS X 10.3.1
- Pro Tools|24 MIX Systems with Power Mac G4, 733 MHz and faster, with Mac OS X 10.3.1
- Digi 002, 002 Rack, and Mbox with Power Mac G4, 733 MHz and faster, with Mac OS X 10.3.1
- Digi 001 with Power Mac G4, 733 MHz and faster, with Mac OS X 10.3.1
so : thanks a lot Digi !!!!!!!!!!!!!!!!
Old 11-15-2003, 03:46 AM
FrankEEE FrankEEE is offline
tchaoo
au revoir
I'm not sure WHAT compatibility page you read - but the one I read at this very moment says (which indicates that 10.3. is supported only - no more 10.2 ... that's all I figured) - no need to say Bye Bye Digi if you got a G4 but that's up to you:
Pro Tools LE — Summary Of Expected Supported Configurations with Pro Tools LE 6.2.2
Digi 002
Digi 002 Rack
Mbox
Mac OS: Mac OS X 10.3.1 only
On the following computers, only with Mac OS X 10.3.1 & Pro Tools LE 6.2.2
iMac G4
PowerBook G4
iBook G4
Synclair ZX-81, 1024Bytes Free
Old 11-15-2003, 03:53 AM
ok : supported : G5 - PowerBook G4 - iMac G4 (!!!).
unsupported : G4 733 and fasters.
i ve got a G4 800 Quiksilver.
Old 11-15-2003, 04:16 AM
audiobob's Avatar
audiobob audiobob is offline
This is rather confusing. If processor speed is the issue, why would Digi mention support for PowerBook G4's, some that could be as low as 400mHz, and not mention G4 towers that could be as high at 1.42gHz?
Old 11-15-2003, 04:34 AM
Rock_Artist Rock_Artist is offline
"supported" or "qualified" doesn't mean it won't be possible.
Imagine Digi would check EVERY possible PC motherboard and cpu configurations... is this real?
Digi qualifies few "latest" systems to be sure they can provide FULL support to those systems. however if a system isn't mentioned under the comptability it just mean digi havn't tested it fully enough to support it.
Many "unsupport" configuration work fine with PT just digi don't have the time to check any system created in the universe.
Just wanna do music,
RA.
Old 11-15-2003, 04:41 AM
TCDet TCDet is offline
This is the new post and I as you am disappointed. My Mbox PowerBook will work in 10.3.1 but not my G4 tower Mix system. Until...........
Maybe we need more programmers on the payroll! (ooops, less profit)
QS G4 2002 dual 1GHz, 1.5Gb ram
(my 2¢ or is that $2 nowadays)
Digi 002 6.2.3 10.3.3 panther radioking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-29-2004 02:10 PM
PT 6.2.3, panther, scsi GOOD! Richard Fairbanks Post - Surround - Video 16 03-21-2004 05:33 AM
Mbox 6.2.2 and G5 Panther 10.3.2 - almost all good DJ Sixxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-25-2004 02:12 PM
panther and digi 001? jes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-12-2003 10:21 PM
Panther and G5 (Good) News. WorldOfWiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-02-2003 01:09 AM
