Old 12-27-2023, 06:00 AM
Jord'n Jord'n is offline
Default From Logic to Pro Tools_Workflow_Bouncing
I'm unsure if this is the best way to start a new thread, but I haven't found anything here that can help answer some questions when switching from one DAW to Pro Tools, in my case, from Logic.
Here are two workflow functions I am looking to find the equivalent of in Pro Tools Studio 2023.9:
1. In Logic, I can cycle an entire track from any starting to endpoints I wish to.
I usually kept my cycle region on from measure 1 to the last measure for ease of bouncing without having to select the range each time I needed to bounce. So far, all I can find in Pro Tools is the ability to choose and loop the range. Still, you can't keep the range selected when editing (of course, I would frequently turn the cycle region off or change it in Logic, but as a baseline, I could always keep it on as needed).
2. File naming when bouncing. Why does Pro Tools always show the name of the previous bounced file when bouncing, forcing me to type in the name of the current session? This is a significant workflow pain point every time I want to bounce. Is there a preference pane where I can change this?
Any thoughts would be appreciated. Thanks!
Old 12-27-2023, 06:07 AM
its2loud its2loud is offline
Default Re: From Logic to Pro Tools_Workflow_Bouncing
1. Unlink Timeline and edit selection. Also. Look up dynamic transport.
2. Because you’re bouncing a new file and it’s going to remember the last file name you chose. Pro Tools has no way of knowing what you’re going to want to name your bounced file. Just type in the file name you want.
Old 12-27-2023, 06:25 AM
uptheoctave uptheoctave is offline
You might find this generally useful if, like me, you have moved from Logic to Pro Tools.
https://www.production-expert.com/pr...hen-i-switched
To your questions:
1. Do you have 'Link Timeline and Edit Selection' turned on or off.
You can find it in the Options Menu, but you can also access it as shown in the attached jpg, or via "Shift /"
2. Do you mean 'Bounce to Disk' under the File Menu, or Track Bounce under the Track Menu?
For the former, that doesn't happen here.
When I open a session called 'Session 1' and bounce it out and then Open 'Session 2' and bounce it out Pro Tools will default to 'Session 2' as the 'Name Prefix'.
If you mean successive bounces in a single session then yes you need to specify the name.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Logic pro and logic pro x doesn't work after mavericks Sanderb Artist Series 3 12-20-2013 12:13 PM
Logic 8 to logic 7 session won't open! saving procedure need crizdee Pro Tools TDM Systems (Mac) 9 04-26-2008 08:09 PM
Logic Pro users: Midi & audio between Logic & PT dtmprod Pro Tools TDM Systems (Mac) 4 09-24-2006 04:16 PM
Logic 5.0.0 crashes all the time.. Is there a Logic expert around here? uno1234 Pro Tools TDM Systems (Mac) 13 04-28-2002 04:23 PM
Hello Logic users.......Please explain about Logic Midi elik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-04-2001 12:35 AM
