PTLE/Digi001:plugs bypass ON&OFF: please HELP!
I put a Limiter plug on the Master track switching it between "bypass ON" and "bypass OFF" thru automation data. All seems to work fine, except for the matter that, when the limiter is bypassed by automation, his insert button becomes grey but it continues to work. So I try to open the plug and switch manually bypass button, but the plug continues to work wether the button is active or not. What I am missing?
Thanks Fulvio
MUSICNET STUDIO Via Puini, 97 57128 Livorno ITALY |
Re: PTLE/Digi001:plugs bypass ON&OFF: please HELP!
The best idea IS delete your plug-in which erases all automation data. Simply re-install the limiter...IF you need one!
www.theflyingdisc.com
Voice Overs |
I noticed it happens only with Bombfactory limiter and not with Digi one.
Fulvio
RTAS plugs lock to bypass mode | Atardecer | Pro Tools TDM Systems (Win) | 8 | 12-05-2007 10:16 PM |
Rtas Plugs Bypass | Siegfried Meier | Pro Tools TDM Systems (Mac) | 2 | 04-08-2007 01:49 PM |
How do u bypass a plugs delay without removing it | olzzon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-22-2006 08:34 PM |
PTLE plugs for PC? | didger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-29-2003 09:41 AM |
Bypass digi001 mic pres thru XLR inputs? | trew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-02-2002 07:25 PM |
