How come Track Input Monitor sounds different than Track Record Enable?
Hello,
I'm running PT HD10 and I don't know if this was common in earlier versions but I notice an audible difference between "Track Input Monitor" and "Record Enable Track". Actually the former sounds better to my ears than the latter. Unfortunately the latter is the only record method I'm aware of. Anyone else experience this?
Armando |
Re: How come Track Input Monitor sounds different than Track Record Enable?
Should they sound different, is this a bug ???
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
try it for yourself.
I can't say I've noticed a different but it just might be my bad ears
Raoul Crane
Don't use TDM here at my studio anymore, but I do at other studios and I've never noticed a difference either.
Thanks Drew!
Guess I should have elaborated more about my setup and what I'm trying to do. I'm recording guitar tracks via a UAD-2 Duo/Friedman amp plugin. I have a DI track for recording the "direct" track and sending that signal to an Aux channel with the Plugin in an insert. I do notice a subtle difference in the tone when comparing Input Monitor and Record Enable. I'll try your suggestion tomorrow and see if that makes a difference or not.
Armando |
Why not simply insert the amp sim on the DI track? Plugins are POST-record so you would still be recording the "dry" signal. Skipping the AUX track should remove the delay compensation "bug" that might be what you are hearing. Having said that, I have never heard a difference here, but I rarely(if ever) route live tracks like that(thru AUX tracks for monitoring)
No, I'm using the Digi 192 I/O.
Armando |
can't record enable a track | macfreak86 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-11-2011 05:11 PM |
audio input tracks sent to one aux track - how do i monitor JUST the aux input track? | awhile | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-17-2010 07:50 AM |
Master Track & Input Track LED peak when record enabled | sharptoothyouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-20-2009 02:11 PM |
When I enable a track to record and then hit 'play' the track will remain silent | Rainerbird | Pro Tools M-Powered (Win) | 2 | 08-07-2009 09:41 PM |
Can't record enable track in DP 3 | clockface | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-29-2003 11:05 AM |
