Bounce Problem
Hi
I have no doubt that there will be a very simple remedy for this but: I just performed a bounce to disk and it recorded me coughing while it was bouncing. How do I stop it from recording my mic? Nothing was record enabled and I tried again turning all the audio track inputs to 'No Input'. I can't believe I have to unplug the mic...do I? Thanks Paul |
Re: Bounce Problem
Wow, you shouldn't be able to bounce a mix with a track record enabled....hmmm.
Re: Bounce Problem
Don't forget, aux tracks and instrument tracks that are set to an input will also pass audio through to the bounce, so make sure it's not just audio tracks you are re-setting the inputs for.
Re: Bounce Problem
Thanks, I've found the problem. Spkguitar, you were right (as is often the case).
For some reason the click track aux, which was hidden, had the input as Input 1. Many thanks Paul |
Re: Bounce Problem
You're going to make his head swell.
Bounce Problem | rjh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-19-2010 01:28 PM |
Bounce problem | theogood | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 05-31-2006 05:39 PM |
Bounce Problem | ThadMac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-08-2006 06:35 AM |
Bounce problem... | saltine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-04-2003 07:42 PM |
Problem w/ my bounce! HELP! | jpoprock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-22-2003 07:08 PM |
