A Good Guide/Tips to Quantize / snap to beat wave pattern.
Hi all,
I've just recorded a bass guitar track for a demo I'm working on. Most of it is fine, there are a few bits where I am moments early/late on the beat. I believe there is a technique called "quantize" where you can snap the start/end of the wave of notes played to the start/end of beats. I've got the pro-tools for dummies book that I'm using as an introduction along with another book of a higher calibre, however I can't find the information on how to get started or do this. Any guide/help/tips would be most appriciated. thanks, Matt |
What version of PT are you using?
In 7.4 there is elastic audio which can do this. For previous versions you can use Beat Detective (which can be tricky for a new user to get the desired results), or just slip audio via editing (which I find often yields the best results regarding the "feel" of the song).
Chris Neal :: South Plains College .: Program Coordinator & Asst. Professor in Sound Technology .: [email protected] .: Pro Tools Certified Instructor .: Pro Tools Expert Certified in Music |
I'm on 7.4,
I'm googling elastic audio. Do you have any more info or a beginners guide. |
Hi Matt,
Not up to 7.4 yet so I've not and experience with how well that works. I can tell you this though. I've found nothing that time stretches or compresses better than Serato Pitch. Just slice the tail end off the note you wish to make longer and it usually works with no artifacts. To compress, do the same, slice at the end and drag the smart tool, (set to TCE) and drag it back. It does take longer than things like elastic audio but I never seen any algorithms that can do the whole line (let's say four words or notes) on the fly. It really depends how sensitive your ears are, and how good you want to edit. Some clients, it just doesn't matter as they couldn't hit the broad side of a bard with a 440 note, but for those projects that really matter, Serato, or Melodyne seem to be the picks.If you have Serato, go into preferences and change to default from the pro tools default to Serato. |
without using elastic audio
tab to transient, A (trim start to cursor) Click to highlight the region Ctrl/Command+Numpad 0 That will snap the start to the nearest grid line Trim the left side of the region out again to the original start. That will at least get you the first note in time and if you're consistantly off it will work well.
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
great tips,
I'll be trying these out today. thank you |
Elastic audio (monophonic algorithm) is perfect for bass. Use it on the bass track, in real-time processing. When you instantiate EA on a track the regions grey out while the audio gets analyzed. When it's done, switch to analysis view to check that the event markers are where they should be throughout the song. Let's say they are, so...
Good luck.
Beat Detective/Quantize Swing Beat | anackman | macOS | 1 | 10-15-2012 07:10 AM |
please help, no wave pattern and no sound from mic | killakelsb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-11-2010 08:45 AM |
BFD LE 1.5 plays preset beat pattern for two measures when I start sequencer again | studiostrat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-19-2009 11:45 PM |
ADR sync - no guide track - any tips? | popcornmama | Post - Surround - Video | 4 | 11-14-2006 09:25 PM |
Groove Quantize.......any tips | DVDave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-23-2004 10:00 PM |
