Old 01-30-2021, 11:42 PM
Southsidemusic's Avatar
Default Need advice on a good way to quantize live drums w/wo plugins
We have started recording awesome live drums again and even though I played for 15 years I hate to play to click and find I tend to ”drift” miniscule amounts sometimes and when compressing and eq’ing and using analog goodness after the takes I do hear some parts where the takes are not 100 and just bought Serato Sample last night to try bit I seem to have skipped the part where it did NOT say for quantizing drum groups hehehe
Serato is addicting so no biggie we bought it but I really gotta ask you guys how you do it??
Is it EA and editing a bit by hand aswell or do you have a better plugin for this?
I just have harsh memories when it comes to EA but that was some time ago to be fair so is it better now with 2020.12 Ultimate?
As always I really am greatful for you guys and will be very happy for any advice on this. ThankYou!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-31-2021, 01:29 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Need advice on a good way to quantize live drums w/wo plugins
Personally I (almost) never use Elastic Audio on drums - it just ruins the transients for me and bugs me every time I hear it, kind of like a low quality MP3. I use Beat Detective instead. You can map the tempo either manually of using BD so you have a grid, then use BD to separate and conform the resulting clips. BD hardly ever gets it perfect though so you'll probably have to adjust some things manually. It can be tedious but is well worth it if you spend the time to get it right.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-31-2021, 01:43 AM
Top tip, before stripping silence make sure you have enough silence BEFORE the transient... easiest way to create cardboard box sound is destroying the beginning of "sample".
Old 01-31-2021, 02:12 AM
Thank you both. So I take it there is no plugin I can read in all 12 tracks of drums with room and overheads etc and just quantize to grid then ....
BD looks ancient and looking at Warren Huart using it I get cramps in my stomach!!!
However I see the results are great so Thanks Chris for the tip. Never even opened BD ever so is it hard to grasp and does it really quantize the audio tracks? Even if each track is consolidated and one long file on each channel?
I thought for real there was a quick way to quantize audio in 2021 as there are sooo little that needs to be done. Its for Elle King and is the song I asked about getting guitars tracked before Xmas but we have that now and super awesome Greatsch Vintage rock drum takes by yours truly and will post the new unmixed version and later the mixed version as soon as the label let me
So again ... quantizing audio is still a no one click does it all then?
This would be soooo easy in Ableton Live10 suite with warp markers and so on but... BUTT PTU ... not so much I see ??
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 01-31-2021, 03:54 AM
Sardi Sardi is offline
Using EA would be the equivalent of warping it in Live. Both are using a timestretching algorithm.
BD works well but it is tedious. No artefacts (typically) as your slicing audio and filling gaps with cross fades.
I’d try EA with the Rhythmic algorithm. You might find it works fine. Worth a shot. You have it.
Gotta ask though... why did you purchase Serato sample to quantise drums?
Old 01-31-2021, 04:20 AM
Christopher:
I know you would know this but send the artist and label both the unquantized and quantized versions and ask which they prefer. I've read too many times where the not-so-perfect version was preferred over the pristine version. As the one who played the drums you know where the warts are but others may not hear it as a problem (if they even hear it at all).
Or you could hire the Atomic Clock Gene Hoagland
Old 01-31-2021, 05:40 AM
Hahaha That was a slightly impuls-y thingamagigg but I wanted it for another task when slicing loops so hoped it would work for this too but been putting buying Sample off and now I bought it. It is addictive and love it for other stuff .
Thanks for the Tip and I will try EA again as it was years ago we tried it.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 01-31-2021, 05:43 AM
Originally Posted by musicman691 View Post
Christopher:
Good point
Didn’t think of that and as I moved the takes until I started solo the individual tracks but as I have to say and accept it is super small stuff and in the mix I can’t hear anything wrong so maybe I will make an EA version and one where I edit by hand the 3-4 kick hits I feel are off by some milliseconds ans send both as you said. Good idea for sure !!
Thanks Guys. You are the Best as usual
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 01-31-2021, 05:57 AM
Whoever is listening cannot tell a difference if you move less than 10ms, take my word for it only fix what is broken.
Old 01-31-2021, 06:59 AM
DontLetMeDrown DontLetMeDrown is offline
Hey, if you really want to dive into this, I give hourly lessons over Zoom and I have a massive collection of unedited drums for you to practice with. Did a lesson last week and it went well. Beat detective requires a lot of custom decision-making. I’m not aware of a plugin or a faster way of doing it better. Not a fan of elastic audio editing (for drums anyway).
Matching sampled drums volume to live drums? any automated way to generate automation Atlanta Bliss Tips & Tricks 14 05-12-2015 12:59 PM
Easiest way to quantize/Build a tempo map from drums not to a click? brandobean Tips & Tricks 5 02-15-2012 05:29 AM
Advice on Separation and Quantize CottersJ Pro Tools 9 8 02-24-2011 04:59 PM
A Good Guide/Tips to Quantize / snap to beat wave pattern. Matt Darcy General Discussion 6 08-12-2008 05:29 AM
Advice for recording live drums w/Digi001 Rober50 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-17-2006 06:14 PM
