CHIPSET Q. NEED HELP ASAP!!!
Hey everyone, im in process of buying a new copmputer...
Here is the setup and tell m what you guys think. CPU: Intel® Core™2 Quad Q6600 8MB L2 2.40GHz 1066MHz FSB MainBoard: GA-P35-DS3L - this is the new chipset RAM: 4GB DDR-2 RAM (Corsair 800MHz Dual Channel - Matched Pair) Video:Nvidia GeForce 8600GT PCI-E 256MB GDDR3 Dual DVI-I D-Sub HDTV TV-OUT I am a little conserned with the mother board. It is a P35 CHIPSET... I wanted the Intel motherboard P75x chipset but they are out.... Is it ok to go with this motherboard and setup or will it cause me problems... Protools LE 7.1 and 002 rack thanks |
Re: CHIPSET Q. NEED HELP ASAP!!!
Hello,
Sounds like a powerful computer. However, I would check with Digi's compatibility documents and with the folks in the Pro Tools for Windows LE section. Good Luck! Len |
Check out the Core2 Systems Spec page and the "Core 2 Duo...Any one got one working yet " thread lots of good info between the 2 threads. The Gigabyte stuff has a incompatibility with Samsung SATA 2 drives. We are all mostly using ASUS boards with the P35 chipset. Check out both threads before you buy anything. Also this is the TDM forum so just stop by the Core 2 Duo thread and pose your questions and we will set you up. P35 is not Digi qualified but thanneither is the QX6600. They are working with PT (as well as anything works with PT)
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
P55 chipset vs X58 chipset, will P55 chipset work? | ToddnTodd | Windows | 12 | 05-21-2011 09:54 PM |
915P chipset versus the 915PM chipset | valleyarts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-28-2005 02:22 AM |
need help asap | Marc Studio | Pro Tools TDM Systems (Win) | 1 | 11-20-2004 01:23 AM |
875P chipset or 865PE chipset | Josh K | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-27-2003 06:21 PM |
Need Help ASAP | mike_ryan | General Discussion | 9 | 10-08-2001 09:07 AM |
