Re: Help needed with 'dinosaur' of a TDM system
Probably has nothing to do with it but it's worth noting that some computers would not see any hardware on first start. Sometimes not even on the second. The third is usually ok. Just one of those things that happened for a period of time.
It still happens to me on a G5PPC every day. I usually have to start twice no matter what order I start the hardware and computer. Just keep that in mind when you are trouble shooting.
HD Accel 2, Magma PER64-I Mac Pro 2x3.2 Quad Core/OSX 10.6.8/VEPro/PT9.03 http://philbuckle.com/ |
Disk I/O card is definately a PTIII system. No Workee with PT v4 and up. You need a Mix card.
Ray Trujillo Freelance Audio Engineer |
Right, a Disk I/O is the main card in a Pro Tools III system, and 5.0.1 as the last version of Pro Tools that ran on it.
The Disk I/O should be in the lowest slot, and you need an interface and hard drive connected to it, etc. Check out http://archive.digidesign.com/compato/pt3/
• linkedin •
OK thanks Ray. But do I have sufficient hardware to run PT 6.4.1 TDM on a PowerMac G4, with just 2 x Farm Cards PCI, and 888 and 882 audio interface?
As he stated you need a MIX card.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#16
See the pre-HD system info at archive.digidesign.com/compato Pro Tools|24 MIX
• linkedin •
#17
#18
#19
What you need is either a d24 core card or a Mix core card if you want to run 6.4.1. You might want to contact the DUC user Pred80R, he has a pile of older stuff he's trying to get rid of, including a d24 card and a PCI expansion chassis, among other things. |
#20
Also, since you're using a G4 you need to check the AMCC chips on the disk i/o and DSP farms and make sure they are all say rev QC or rev QE. The rev Q chips are not G4 compatible.
Dinosaur Help | Jim O'Brien | Post - Surround - Video | 5 | 03-05-2010 04:42 AM |
dinosaur returns to the fold... | shulala | Pro Tools M-Powered (Win) | 5 | 12-05-2005 12:58 PM |
dinosaur has upgrade questions | gleiter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-14-2005 08:10 AM |
001 dinosaur user here...CPU issues. | rangeroad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-22-2005 12:45 AM |
Is my G4 400 Good enuff or dinosaur? | thumbolt68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-15-2003 08:13 PM |
