Digi 001/MOTU 2408 Mk2...
I've just bought a MOTU 2408Mk2 and am having difficulty setting it up. I want to run eight individual outs from my MPC into the MOTU and then from the MOTU into the 001 pci using an ADAT lightpipe cable.
Help me please.
Pro Tools Digi 001/MOTU 2408Mk2/Akai MPC 3000/Roland VP9000/Technics 1210's/Vestax PMC 05 Pro 2/Yamaha MSP5A's |
Re: Digi 001/MOTU 2408 Mk2...
Where exactly are you having difficulties ?
Should be a simple configuration.. How is everything hooked up ? What is the clock setting on the MOTU, and in PT ? cheers,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Basically got eight 1/4" jack cables going from my MPC into the MOTU. I've then got a lightpipe going from the MOTU into the 001 pci. In the Pro Tools session I've got the input of a track set to ADAT 1 and a MIDI track triggering the MPC. I've got the lightpipe coming out of ADAT 3 and I have set it on the front of the interface accordingly. It might be that I havn't set the clock correctly and that is where I'm getting confused.
If you have signal going from MPC>MOTU on all 8 channels, than the bank's optical OUT should connect to the PCI cards ADAT IN. This is the one with NO red light inside..
PT clock should set to external, ADAT optical in. MOTU is on internal, of course. Sample rates MUST match between the MOTU setting and the PT session. In the session you'll need to set your inputs to whatever you have named the ADAT 1-8 ins in the IO setup... good luck,
Worked like a charm. Cheers mate.
R&R !
Digi 001 vs. Motu 2408 | jorofino | General Discussion | 6 | 03-30-2001 10:08 AM |
Digi 001 Vs. MOTU 2408 | lfont | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 43 | 11-14-2000 06:19 AM |
Digi 001 vs. Motu 2408 | AlinMV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-18-2000 01:10 AM |
Digi 001 and Motu 2408 | MT Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-18-2000 08:15 PM |
MOTU 2408 vs Digi 001 | zingsthings | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 11-05-1999 03:12 PM |
