Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 04-28-2023, 12:03 PM
Tone_Mechanic Tone_Mechanic is offline
Default Re: MTRX STUDIO + Thunderbolt 3
Originally Posted by uptheoctave View Post
I have the AX64 with the Thunderbolt card.
It works as a core audio driver should.
It is way better than DVS.
In terms of latency… this is at 48kHz with 32 sample buffer.
That is fantastic. That's exactly the information I was looking for.
Thank You!
Old 04-29-2023, 02:57 AM
uptheoctave uptheoctave is offline
Originally Posted by LDS View Post
Oblique RTL Utility will give you a firm measurement based on a loopback test, rather than relying on the drivers reported latency - https://oblique-audio.com/rtl-utility.php
It would be interesting to see the different in latency between a digital loop through the DADman routing matrix, and a physical patch between DA output and AD input. I don't think the reported latency in Logic is really able to tell what routing you are using within the AX64.
Edit:
Done it.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 04-29-2023, 06:25 AM
Quite a few of the low buffer settings report 'Suspect Result'.
Not sure why- there doesn't seem to be anything about it in the manual.
James Richmond
Affiliate Links:
Old 04-29-2023, 08:25 AM
BScout BScout is offline
"the "suspect" flag gets raised if: test signal not detected, measured <99% of reported latency, measured >125% reported, or other technical anomaly with the return signal like the effect of too much noise."
For the smaller buffers, the reported vs measured difference (in percentage) grows massively.
Which is partially normal in statistics.
Old 04-30-2023, 06:55 PM
LDS LDS is offline
Thanks James. Not too shabby at all!
Are those measurements just digital loops using the DADman matrix? Or are they using DA & AD cards?
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
  #16
Old 05-01-2023, 11:31 AM
That is using ADA.
James Richmond
Affiliate Links:
  #17
Old 05-01-2023, 05:38 PM
I did the test again at 44.1kHz and 96 using digital loopback by passing the ADA stages.
https://i.imgur.com/fzgYBN2.jpg
James Richmond
Affiliate Links:
  #18
Old 05-02-2023, 01:19 AM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
It seems that you have made a patch in the AX64 routing matrix and not done an external digital loop-back via e.g. MADI or ADAT. That explains why the measured RTL is faster than the reported RTL.
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
  #19
Old 05-02-2023, 01:57 AM
Hi Jan, yes, this is true.
I did a previous test using the ADA. I wanted to compare the latency between using ADA vs not. I will do one using AES/MADI loop back later today.
James Richmond
Affiliate Links:
  #20
Old 05-02-2023, 02:59 AM
Here is reading using Digital Loopback via AES, rather than just the TB to TB patch in DADMAN.
Sorry if it was confusing for people.
James Richmond
Affiliate Links:
Apple Mac M1 MTRX Studio HD Native Thunderbolt IrelandM Pro Tools HDX & HD Native Systems (Mac) 19 01-07-2023 03:01 PM
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX Studio Headphone Outputs vs HD Native Thunderbolt Box scottmckay Pro Tools | MTRX & MTRX Studio 3 07-28-2022 09:22 PM
MTRX MTRX Studio Forum Section? off the wall Pro Tools | MTRX & MTRX Studio 2 05-08-2022 03:20 PM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
