Applying a 44.1khz session to 88.2khz Audio Files
I have some material that is recorded at 88.2khz that I would like to edit at home. My set up there will only go as high as 48khz and while I am happy to create a 44.1khz session and SRC the files to 44.1, I am hoping that I can apply the edits to the 88.2khz files without having to convert back up.
I have tried using region groups ,exporting region definitions and importing session data but all of these SRC the 44.1khz files back up. Is there a way to use the 44.1khz session with 88.2khz files? Thanks
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
Re: Applying a 44.1khz session to 88.2khz Audio Files
There is now way to do this, beside SRC your files to the session sample rate of your other system.
Pro Tools 10 has added support for files of multiple bit depth in the same session and you can also mix and match audio file types (.wav, .aif and .sd2, but not .mp3) But also in Protools 10 you will be given a warning if the sample rate does not match. So same (logical) problem. Grz, Louis |
Top Jimmy, you are in fact Top!!!
This will save me having to do all the beat detecting again. Thank You
usaved PT session saving unsaved audio files to audio files folder | mermermer | Pro Tools HDX & HD Native Systems (Mac) | 1 | 07-18-2012 11:50 AM |
Importing 32bit, 88.2khz files - How!! | Johnrg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-11-2011 12:53 PM |
Record in 88.2khz > edit&mix on Mbox 44.1khz > back to 88.2khz | chavernac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-21-2010 05:48 AM |
dae error -6006 when creating new session of 88.2Khz | ith_e | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-12-2009 08:47 AM |
Some opinion please. Using 24/44.1khz equipment when mixing in 24/88.2khz | Khaarmeyer | Pro Tools TDM Systems (Mac) | 1 | 03-05-2009 10:37 AM |
