Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 02-13-2022, 09:08 AM
Jvadillo Jvadillo is offline
Default S3L DSP cards
Since I have two E3 engines sitting at my closet I was wondering if their DSP Cards would work on my S6L. Do they have a different form factor or firmware? If so can it be adapted/flashed to be compatible?
Any help appreciated.
Old 02-14-2022, 07:47 AM
emluper emluper is offline
Default Re: S3L DSP cards
They say no, but they look like the exact same card..... however, I would be wary of "purposely" causing damage to an E6L engine that voids the warranty. Getting it repaired would probably be fairly expensive.
Old 02-15-2022, 08:52 AM
Valentyn Valentyn is offline
Cards are either physically the same or not (both cases do exist). But even if they're the same, they have different firmware which makes them fully incompatible.
Old 02-18-2022, 01:21 AM
I assumed they had different firmwares, just wanted to check if said firmware could be replaced/updated to an s6l firmware. Some insider feedback from avid would be great, as now I have two big paper weights on the e3…
Accel Cards next to other PCIe Audio Cards in the same Mac Pro for PT 10+11? relaxo Pro Tools 11 12 05-14-2020 02:05 AM
Mac 12 Core + 2 Hdx Cards + Magma Digi Rev B + 3 Uad Octo Cards + Pro Tools 12.8.3 drago76 Pro Tools 12 2 12-19-2019 09:38 PM
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 02:39 PM
PCIe cards not being recognized in my MAC PRO ProTools not launching with cards in phatbeatstudio Pro Tools TDM Systems (Mac) 6 10-15-2011 11:35 PM
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! A Spooner Tips & Tricks 6 07-08-2009 06:55 PM
