Transfuser makes PT quit
I'm running 7.4. in OSX 10.4.11. Everything otherwise runs fine. When I load Transfuser everything is okay until I try to load .wav drum sounds from my library. When I select a sound and try to drag it to the pads, PT immediately quits. Any thoughts?
"I'm not really HoboSoul™, but I play him at the DUC..." Mac Pro 12Core 3.46G (5.1) | 64G Ram OSX 10.11.6 | PTHDN/OMNI/Apogee Duet(non Avid) 10.3.6 / 11.3.1 Need mixes, mastering, guitar, keyboard or bass parts added to your tracks? Need custom songs/music written and produced for special occasions? Check out The Soundz Shop. Great work by pros with multi-platinum experience at excellent prices... |
Re: Transfuser makes PT quit
That's normally a file issue bud, try doing a verify and repair. Also make sure the audio is the same sample rate as the session.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Hey, Russ. By 'file issue' do you mean the .wav file itself? 'Cause no matter what file I use, PT quits. Even files I made in PT...
Have you done a file verify and repair?
Yessir. Any other thoughts? I can work around this issue. But I'd like to be able to load other than factory sounds in Transfuser...
Oh. Wait a minute. How does a 'file varify and repair' differ from a disk varify and repair? Or does it?
I may mean the same thing but have some kind of bug today so my thinking is dulled.
I mean disc permissions. What happens if you try and drag a wav from the desk top?
Okay. I'm able to drag some sounds from the desktop. But, dragging the same sounds from the browser still makes PT quit...
No one else seeing a similar issue?
I have the same problem on PT 8.0.1 and Transfuser.. PT Crash, or it takes a lot of time to show me the folders.... I 've updated everything tonight, and it works better.. but still buggy... Another question... I would like to add a personal list of "Snares" "Kicks", etc etc to the drum presets... So I can scroll sounds in "Play" mode really fast... How to do it??.. I |
MC Control makes pro tools unexpectedly quit. | filmsound_no | macOS | 5 | 08-19-2013 10:26 AM |
installing Transfuser full on Transfuser trial | wfasano | Virtual Instruments | 2 | 06-30-2009 03:14 AM |
Transfuser on the master fader with ADC enabled makes bpm effects out of sync. | Rubicon | Virtual Instruments | 6 | 09-25-2008 10:43 AM |
simple copy makes PT quit, Even more questions now | andre tchmil | Pro Tools TDM Systems (Mac) | 29 | 05-10-2007 03:27 PM |
MIDI makes PT6.4 quit unexpectedly + cs9 question | bluerockgod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-18-2004 06:00 AM |
