copy clip gain bug?
Make a long audio region and duplicate it on the track below (30 seconds long is enough). Draw some clip automation to the first region (the original not the copy). Use copy clip gain and paste the clip gain to the region below: the clip gain paste will be out place by a lot. In my system, the 'pasted' clip gain is always way off. So, copy and past clip region is unusable.
I have had this bug since clip region was introduced, I was hoping PT 11 would fix it, but it is still there.. |
Re: copy clip gain bug?
I will try that -
Have this problem in 10. The workaround is via quick keys:
Source clip: Control-Shift-C Target clip: Command-V See if that works in 11. |
Adjusting Clip Gain On More Than One Clip | Blank Frank | macOS | 17 | 05-15-2015 06:34 PM |
AudioSuite Gain/Normalize also on Clip Gain | A-n-d-i | macOS | 0 | 03-13-2014 12:46 PM |
Export Clip With Clip Gain | BobbyDazzler | Pro Tools 10 | 0 | 03-03-2013 03:06 PM |
Clip gain copy/paste bug | yop22 | Pro Tools 10 | 6 | 02-21-2013 07:22 AM |
Clip gain on clip groups: bug or feature? | idris | Post - Surround - Video | 6 | 01-02-2013 10:48 PM |
