Re: structure, strike, transfuser, velvet -HELP
I've read posts about a similar issue with Xpand. One solution was to make sure the permissions for the folders that contain the content are set to read & write for your MAC user account. Then reinstall the VI's but without the content. Custom install should do this.
hi phil, permissions are correct ... and i have re-installed without contents several times ...
no love ...
Re: STRIKE content not found in ML
still nothing ... the NEW AIR inmusic does not support the older versions ONLY avid does ... do i really have to pay for tech support for these to work again .. why did they stop .. oh yeah, this has been an issue for years ...
• linkedin •
yes jeffro ... the Doc you directed me to ... replies in caps ...
Use the Set Strike Content Location application for Mac OS X or Windows - it needs to be installed in the same folder as the data files (e.g. "Strike data1.big") then launched from there. This app is also included/installed with Strike. IT IS iN THE RIGHT PLACE ... Update the Strike plug-in and Set Strike Content Location app after installing Pro Tools 10 Mac. YES, AFTER PT INSTALL !!! Use the Strike Pref Installer (note that having an admin account without a password might prevent this installer from working properly). (AND I HAVE A PASSWORD) 1. Copy the "Strike Preference File Installer.command" file to the Strike content folder. The content folder was created during Strike installation. If you have chosen the default path, it s "/Applications/Digidesign/Strike". If you don t remember the path, search on your computer for the folder that holds the "strike data 1.big" file. THERE IS NO DIGIDESIGN FOLDER ANYMORE ... THERE IS ONLY AN AVID FOLDER ... Reinstall Strike. Repair Disk Permissions with Apple's Disk Utility or delete the following files from Mac HD > Library > Receipts if the first attempt at reinstalling fails on any of these files: Strike Content 1 Setup.pkg Strike Content 2 Setup.pkg Strike Setup.pkg THERE ARE NO FILES LIKE THIS IN THAT FOLDER ... Verify that the Mac OS X System drive is formatted as "Journaled" and not "Journaled, Case Sensitive" (use Disk Utility). YES ... AND LAST ... Manually edit the com.digidesign.strike.Plist file in Home > Library > Preferences to reflect the path of the .big files. NOW WHY SAY TO DO SOMETHING AND NOT EXPLAIN HOW ???? not sure what part of this was meant to help but no love there ... cheers john
#16
Applications > Digidesign > AIR Content If you changed the path for the content when you installed Strike it will install the Strike folder (with presets and .big files) in that other location, but it still creates a Digidesign folder (in Applications) for the Documentation. Quote:
• linkedin •
#17
thank you jeff for all the all the info ... i will test the text edit tomorrow ... cheers john
#18
I wanted to double check this on 10.8.3 (listed in your sig) so I installed PT 10.3.5 and Strike 1.5 on my 10.8.3 partition. I then ran the Strike 1.5.1 update from http://avid.force.com/pkb/articles/e...ssage/en425695
I also downloaded the Set Content Location for Strike from that page to the same folder as the Strike data and ran that. Strike worked normally with all its data. I then checked the plist file and noticed what you mentioned - it doesn't display the full path like in 10.7.5. Maybe you could reply with the path to your Strike data folder and I can investigate further.
• linkedin •
#19
hi jeff ... success ... but not how we thought ...
i have included a pic of my Plist in it's natural habitat so you can see what i see ... solution for Me today: there is now a Digidesign Folder again ... I tossed all strike, velvet, transfuser content only Not the plugins (these 3 are the plugs that were not working without the Digidesign folder / strangely - structure is still in the avid AIR content folder and is just plain happy) Since i have all my installers on a drive as DMG's i just reloaded using the Main Installers, then doing updates as you did ... but the big thing i saw was when i reloaded the Content for the Big 3 (no pun) it ran the Set Content App automatically like it should ... i looked at the textedit solution we spoke about but as you see by the pics i did not see much to work with ... jeff, thank s again for your help ... IF it rears it's ugly head at random once again i will return here and post results .. cheers john SO ... Solution this time was to reload the Content (having Disk Images, ie: DMG's available saves a lot of time ... only took about 15-20 minutes for installers and updaters ...
Strike - Content not found | Vincent Joly | The Drum Room | 5 | 10-02-2011 06:21 PM |
Strike - Content not found | xq3js | Virtual Instruments | 18 | 09-29-2009 12:50 PM |
Velvet & Strike: Content Not Found error | thopman | Virtual Instruments | 13 | 07-20-2009 06:14 PM |
Strike Content File not found | atomicaudio | Virtual Instruments | 1 | 07-01-2007 06:55 AM |
Strike - Content Not Found Message When Opened 1st Time | SHC | Virtual Instruments | 2 | 05-10-2007 07:56 AM |
