Compatability with Avid Adrenaline interface
I presently have an Avid Newscutter Adrenaline FX running on a Windows XP system. If I want to add ProTools LE software to run on this system do I also need to purchase an 001, 002 or Mbox or can I use the Adrenaline interface? Any help? I will not be running the applications simultaneously. I plan to edit my video and audio, export it as an OMF, sweeten in ProTools then re-import to Avid. Any assistance would be welcome. Thanks
Re: Compatability with Avid Adrenaline interface
The Adrenaline box can't be used as an interface for Pro Tools. Avid/Digi only garuntee compatiblity between Avid and Pro Tools with the Avid Xpress Studio bundle for LE, or w/ Mojo and/or V|10 + Mediastation for Pro Tools HD.
What you could do is buy the mbox or 002, install a second copy of XP onto another drive or partition on your Adrenaline system, and then reboot into that system when you want to run Pro Tools LE. Not the most elegant workflow but it will work. Bottom line, don't install Pro Tools on the same OS as Newscutter (it will most likely corrupt your Newscutter install) and you should be fine. HTH ~turbo |
Thanks for the info
Thanks for the info
Protools and avid adrenaline interface for video | Dan Downs | Pro Tools TDM Systems (Mac) | 1 | 06-11-2012 06:46 PM |
Video from an Avid Adrenaline | Jeremy Lock | Post - Surround - Video | 1 | 08-29-2006 09:29 AM |
Avid Adrenaline to Avid Mojo | uno1234 | Post - Surround - Video | 4 | 06-11-2005 07:11 AM |
Avid Adrenaline to Protools HD via Unity | feliponk | Post - Surround - Video | 2 | 02-12-2004 08:24 AM |
Avid Adrenaline to Protools HD via Unity | feliponk | Pro Tools TDM Systems (Win) | 0 | 01-18-2004 05:37 PM |
