Re: headphones sound better than any type of speakers, have tried everything.
Problem : I'm almost sure that the way way you have things set up, your volume knob that controls the headphone volume is probably between 4-6 which is the cause of the problem. Your receiver or powered speakers are receiving this 4-6 volume level and it's probably not enough or a proper signal for best signal to noise ratio also. Solution: Set the volume knob that control rig volume/headphone volume to somewhere between 8-10. I have mine set at 10 and I believe I get the best signal to noise ratio to my studio speakers. This will create a small problem for the headphone volume that will be very loud, but there's a small solution from "user options" go to "Headphone Volume"." This control sets the volume of the Headphone outputs on Eleven Rack, as an offset from the Main output volume." To explore User Options mode from the front panel of Eleven Rack: 1 Press and hold the Edit/Back button until the User Options screen appears. 2 Turn the Scroll wheel to select the option you want to change. 3 Press the SW1 button to access the controls for that option. 4 Press Edit/Back once to return to the User Options menu, or twice to exit User Options mode and return to the previous screen. http://akmedia.digidesign.com/suppor...ide_v801_62404. |
Of course, when you're listening through headphones you're not having to deal with any "room deficiencies".
If you're room is less than optimal nothing is ever going to sound its best in there. This is why recording studios have all of that acoustic treatment. Are you perhaps expecting too much from a sub-optimal room?
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Well, try the SPDIF out toyour monitors, if they don't have SPDIF, trying going into another audio interface that has SPDIF if you have one. If that doesn't work, then contact Avid for Warranty information. If you haven't registered the Eleven Rack, register it and contact support.
Also can you tell us what outputs are you using, XLR or amp out etc into what? Based on what I remember you saying that the recorded sound is fine I'm lead to believe that the fault can be in how you're connecting the Eleven Rack |
Can you please tell us EXACTLY how you are connecting speakers to the Eleven Rack?
Can you please tell use exactly what speakers you are testing this on? At what point in the chain are you sending the signal to the speakers? Are you certain you have the FULL RIG for the output(s) you are using? Can you record a sample so we can hear it?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
#16
and full rig out option is set i'll try to record something when i have a chance thanks |
#17
And what headphones are you comparing to?
#18
some cheap in ear phones, i tried ath-m40fs, didn't like them
#19
As you said, it sounds better. Of course it does. The speakers(headphones) are on your head. There isn't a distance involved. I always record with headphones(neighbors and I like to feel like I'm in the mix) and mix with monitors.
😜 Sent from my iPhone using Tapatalk.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
ASIO4ALL2 - Meters Go Up, But No Sound From Headphones Or Speakers! | epu | Pro Tools 10 | 2 | 06-22-2012 02:16 AM |
ASIO4ALL2 - Meters Go Up, But No Sound From Headphones Or Speakers! | epu | Windows | 0 | 06-21-2012 02:58 PM |
All about Headphones/Speakers | smrpg99 | General Discussion | 3 | 06-05-2011 02:16 PM |
Monitoring with speakers and Headphones | oettinger1919 | General Discussion | 3 | 11-25-2009 07:06 AM |
Speakers and headphones | karlc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-30-2007 09:53 AM |
