Old 07-13-2021, 01:24 AM
noobstudioguy noobstudioguy is offline
Default Recording there, mixing here
Much love and appreciation in advance.
Question:
If I record at a studio, and I wanna mix at my studio. Whats the best route?
1. I dont care about the plugins at the other studio, I would rather use mine.
2. I dont care to keep anything from the other session except the *DRY VOCALS* and the instrumental (the session audio files).
Should I export everything as wav and import as a new session into my studio OR should I import session data?
Using Pro Tools 20/21
Old 07-13-2021, 01:58 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Recording there, mixing here
Why so complicated? Copy the session file and audio files of needed tracks, then open at another studio. It will obviously alert you that some files are missing (in case you did not copy everything), but you can just delete the unwanted tracks from the session. If you want to copy everything, the easiest way would be "Save Copy In"
Janne
Old 07-13-2021, 08:10 AM
arche3's Avatar
arche3 arche3 is offline
Drag entire session folder onto your own drive. Plug into your computer. Open.
Sent from my SM-G986U using Tapatalk
Old 07-13-2021, 09:14 AM
This^^^unless the studio uses a different DAW. In that case, just make sure: 1-every audio track(per song) is a single wave file starting at the exact same point in the timeline(even if its not 00:00:000). That way, when you import the files into a new session on your rig, if you start them all at 00:00:000, they will all be in perfect time.
2-make sure that EVERY audio file is named(the last thing you want is a folder full of files named audio1, audio2, audio3....)
3-make sure the audio files are at a sample rate that your setup can handle(although, sample rate conversion has gotten pretty darn good)
4-if you work with a click, note the BPM for each song.
5-the studio could export each song as an OMF, which should open in PT(but the previous instructions are guaranteed to work)
Old 07-13-2021, 09:17 AM
JFreak's Avatar
I thought the point was OP does not want to copy all of that audio, just session data and few selected tracks
Janne
Old 07-13-2021, 12:03 PM
arche3's Avatar
How do you own a recording studio and don't know how to tranfer a session. Not judging.
Old 07-13-2021, 12:36 PM
K Roche's Avatar
K Roche K Roche is offline
Well his user name is noobstudioguy so either it's literal or maybe like me, by "my studio" he means my home studio ?
But I agree ,,, save the entire session then just delete what isn't needed, is how I have done it a few times. Although it has always been from PT to PT,,, Back then it was TDM to LE and I think it was something like "Save session data"
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 07-13-2021, 12:59 PM
ZEUSS ZEUSS is offline
I would not do that. Always do a "Save Copy In"
You never know if all of the files will make it. I have seen disc allocation issues for years doing it that way. Then if the studio deletes the original your screwed.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 07-13-2021, 01:27 PM
seanmccoy seanmccoy is offline
Totally agree, it's the only completely safe way. It's very easy when working at a remote studio to accidentally path the audio files somewhere you didn't intend. And if you'd prefer not to transfer unused files, it's easy to remove them from the session before doing the "Save Copy In."
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 07-13-2021, 01:30 PM
cwsand's Avatar
cwsand cwsand is offline
My 2¢ - Make a copy of the original session and leave the original session untouched in case something gets really screwed up or files go missing - happens to me way to often!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
getting started with recording/mixing Matt26 Pro Tools M-Powered (Win) 4 06-14-2010 03:12 AM
Serious recording/mixing puckot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-04-2004 10:16 AM
Recording in PT- Mixing in SSL Aardvark Tips & Tricks 3 03-11-2003 05:18 AM
Mellotron recording/mixing? tzujan Tips & Tricks 7 03-19-2002 02:38 PM
Recording in PT-Mixing in SSL Aardvark Pro Tools TDM Systems (Mac) 2 11-10-2001 12:41 AM
