Old 04-12-2013, 03:47 PM
adam79's Avatar
adam79 adam79 is offline
Default Installing PT 8 LE on Snow Leopard
Has anyone successfully installed PT 8 LE (or lower) onto a Mac running Snow Leopard (10.6)? It installs smoothly, but when I try and open it, I get an error: Unable to locate Digidesign hardware." The MBox 2 shows up in the control panel, though. I originally installed Pro Tools on Leopard (10.5) and it worked fine after I updated to 10.6. I recently did a clean install, which is why I'm installing PT again. I'm hoping I don't have to reinstall the OS again, this time starting w/ Leopard, installing PT and then running the 10.6 upgrade.
Thanks,
-Adam
Old 04-12-2013, 04:48 PM
lancemcv's Avatar
lancemcv lancemcv is offline
Default Re: Installing PT 8 LE on Snow Leopard
Make sure you have the correct MBox driver to match the OS version.
Old 04-12-2013, 08:25 PM
adam79's Avatar
I updated to PT 8.0.5 LE, which supports Snow Leopard and I still get the same error. I have the most up to date firmware for the MBox 2, ver 1.43. Please Help!
Old 04-12-2013, 08:32 PM
adam79's Avatar
Could the 1.43 firmware be what's giving me problems? Is there a way that I can downgrade to 1.38 and see if that works?
Old 04-14-2013, 05:13 AM
Chief Technician Chief Technician is offline
Exclamation Re: Installing PT 8 LE on Snow Leopard
Possibly. That firmware update only addressed a problem with DAT decks and was otherwise untested.
Maybe. I don't own an Mbox 2 so I cannot comment further.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 04-14-2013, 05:18 AM
adam79's Avatar
What interface do you use? Maybe it's the same process to uninstall/reinstall the firmware. You know how to do it with your interface?
Old 04-14-2013, 07:11 AM
Arrow Re: Installing PT 8 LE on Snow Leopard
I use my MacBook Pro's built-in audio I/O.
Old 04-16-2013, 11:33 AM
adam79's Avatar
No one has any suggestions? I've been messing around with this for days now with no luck. I noticed that in the Audio MIDI Setup utility the MBox 2 shows up, but it says 0in/0out. So it's being recognized, but there's a problem with the communication. Please Help!!!!
Installing PT HD 8 on Snow Leopard Davidwilson macOS 4 02-26-2014 03:57 PM
Installing PT 7.3 LE on Snow Leopard - Mac OS X 10.6.8 adam79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-14-2012 07:13 PM
MacBook Pro w/ snow leopard + Installing/upgrading fbmedia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-31-2010 06:53 PM
URGENT: Installing 8.0.0 -> 8.0.4 on snow leopard Inthebox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-01-2010 12:14 PM
PTLE 8.0 with Snow Leopard: Disc Ejects w/o installing SoboJoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-04-2009 11:28 AM
