#261
Re: Low Latency Tracking without Pro Tools HD Native or HDX
Second, they did not "add" input monitoring. It has always been there (alt+k shortcut to toggle on and off). They just changed it from a universal to per track basis. Nothing changes except the ability to have tracks to monitor input and not record them.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#262
guitardom,
Sorry if I didn't make it clear enough that HDX, like other third party interfaces with internal mixers and plugins/effects, can monitor over the low latency (0.7ms) upper path. It, also like they the others, can operate over the high latency lower path through PT (adding another 2.33ms of latency when native plugins are used with HDX). Thanks for pointing out the need for some clarification - please let me know if you still disagree. Do you (and others) understand the table? Is it correct? How do the AVID interfaces that support LLM work with PT, PT HD native, and PT HDX? Thanks for correcting me on the Input Monitoring thing! Amack Quote:
#263
Re: Measuring Latency, Scarlett 6i6, DiGiGrid, etc.
Why is thread still active ?
#264
Apparently it was re-opened to move my "Low Latency Tracking without Pro Tools HD Native or HDX" thread to it. See post #253 in this thread.
#265
Not really. Native plugins are completely disabled on any armed/monitored channels during recording with HD TDM and HDX.
It's a completely different beast. Buffer is irrelevant when speaking of *recording* through plugins on PT DSP systems. I certainly understand what your point is, but it doesn't apply to HDX, as HDX does not work in the manner you describe when recording, unless you trick it into doing so. Quote:
#266
Can you agree that setting DA/AD track insert with latency compensation on, using PT shows actual and reliable RTL figures? This is when PT uses full output and input paths to phase align tracks. There is nothing to hide using this method - all latencies present whereever have to be inluded!
Results are audible - 2 identical tracks are either aligned or comb filtered. Am I missing something? |
DigiGrid IOS 8IO+ DSP | simon.a.billington | AAX Plug-ins | 0 | 12-04-2014 07:10 PM |
Measuring Analog Distortion? | SuperReverb | Pro Tools TDM Systems (Mac) | 2 | 10-18-2010 07:02 AM |
Correctly measuring input db | PTGuy | Pro Tools TDM Systems (Mac) | 4 | 05-12-2006 12:36 AM |
Measuring Midi Latency | JPS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 07-01-2002 10:24 PM |
Measuring the latency (experiments) | jnash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-16-2000 10:15 PM |
