#101
Re: Measuring Latency & Scarlett 6i6 Beta Results
guitardom,
Sorry about my last post, the other guys responded while I was writing it. You’re right about some ASIO interfaces incorrectly reporting input and output latencies though. Although it’s admittedly a small sample size, I think I’ve detected a pattern in mine that can predict if they do or not. Unlike those devices that do report correctly (Studio Capture – always and Scarlett 6i6 Beta - sometimes), those that don’t all show “System Delays” that don’t vary with “H/W Buffer” size variations. That includes ASIO4ALL, Echo AUDIOFIRE4, Fast Track Duo, and Eleven Rack. I wouldn’t count on that though; especially since it’s probably easier to use the posted approach to find out for sure (as well as help ensure that everything is setup correctly and performing as expected before recording/tracking sessions)! Amack Quote:
Last edited by Amack; 06-10-2015 at 08:19 AM. Reason: Remove minus “H/W Buffer” sizes |
#102
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#103
That sounds like clear thinking to me! I, and likely many others, would like to see real RTL numbers for the various types of interfaces and DAWs out there. It seems to me that a separate DUC category/folder for that information would be quite useful (although AVID likely won't want those numbers advertised so that's not going to happen!) Also, the numbers shouldn't vary much/any with different DAWs.
But, at least if you stick with Windows, it's PT that's likely limiting the overall DAW's performance/latency, not a modern 3rd party interface that's "stable" with PT. See http://duc.avid.com/showthread.php?p...=1#post2264405 for additional information. Thanks Again for Helping Out!! Amack Quote:
#104
This second loop is not representative of any sort workflow or any situation we have to think about. You can think it represents what you want, fact is that it is not representative of anything really useful. If everything is compensated for on your interface on the first loop, where is the problem and what is not right even though the Second loop may say 213 samples???
#105
It is actually the first loop (which should be zero) that is unimportant - unless its not zero - in which case it is also very important and needs to be compensated for either via a DAW setting or in ProTools by using DDMF Metaplugin. If you don;t your recorded tracks are out of sync with what you played them to. How is any of this not important or at the very least - valuable?
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
#106
#107
Use one loop then and save the expense of the 2nd cable! But, the 2nd loop doubles the distortion produced by the interface and thereby makes it more visible (even more would be even better depending on how much you care or want to know). I used 4 on my Studio Capture
#108
You obviously need to answer this question and think about it. What does it mean if the first loop shows everything is correctly compensated for and the second loop shows its off?
#109
Additional signal (sound) distortion. How can it be "off" if PT doesn't screw up?
#110
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
DigiGrid IOS 8IO+ DSP | simon.a.billington | AAX Plug-ins | 0 | 12-04-2014 07:10 PM |
Measuring Analog Distortion? | SuperReverb | Pro Tools TDM Systems (Mac) | 2 | 10-18-2010 07:02 AM |
Correctly measuring input db | PTGuy | Pro Tools TDM Systems (Mac) | 4 | 05-12-2006 12:36 AM |
Measuring Midi Latency | JPS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 07-01-2002 10:24 PM |
Measuring the latency (experiments) | jnash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-16-2000 10:15 PM |
