New Macbook Pros out today! I5, I7!
Re: New Macbook Pros out today! I5, I7!
As I read more I'm learning that these have dual graphics cards (interesting) and available solid state drives. And all the I5 and I7 processors have hyper-threading, where as with the Imac, only the top of the line extra cost (2199) processor has hyper-threading.
According to the website, these processors give up to 50% more processing power than the previous Macbook Pro. Now that these are out, I'm wondering when we're going to see new Mac Pros. Now it might be a few months, darn it! |
bump.
Thanks for sharing!
The question now is: imac i7 or MBP i7? Hmm.. |
Yeah, I was wondering that myself. On the Imac, you have to go up to the $1999 model to get the I5, and another $200 for the I7. And only that I7 actually has hyper-threading, if you read closely.
On the Macbook pro, you can start at $1799 for the 15 inch I5, but it and the ones above it all have hyperthreading. The available solid state drive is also a nice option. I think this puts them as a very nice option for running Protools if you decided to only get a laptop. Or a very good second computer for those using Vienna ensemble pro and similar products. |
The specs on the Apple site state that these new dual core processors are 2.66 Ghz however my macbook pro has a 2.8Ghz Intel Core Duo. So mine is faster and is still has 2 cores. So technically wouldn't mine perform better?
Mac mini OS 10.15.6 3.2Ghz 6-core 8th Gen i7 64GB RAM/1TB ProTools 2020.5 MOTU 828 MkII Genelec 8020/7040A Glyph GT050Q Novation SLK MkIII www.YourSessionBassist.com www.soundcloud.com/davedemarco |
Built-in Hyper-Threading allows two threads to run simultaneously on each core, so Mac OS X recognizes four virtual cores instead of just two. When you’re running multiple applications at once, the Core i5 and Core i7 processors spread tasks more evenly across a greater number of cores — so you can get more done, faster.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Looks like they are using the i5-520m and i5-540M which are dual-core with hyperthreading and turbo boost. So these should show as 4 cpu's in PT and with turbo boost can run up to 2.93 or 3.06 GHz respectively. Sounds like there should be some nice performance with these.
However it's the i7 that should be a beast. I'm not sure exactly which processor it is, but it should be a quad-core with the same tech as the i5. So 8 cpu's in PTLE. That would be nice.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Also, clock speed isn't directly related to a chip performing "faster". As noted, the Hyper Threading adds power, as well as direct CPU access to the RAM (no bridge) and a new type of chip architecture. Should be interesting to get Pro Tools loaded onto one of these, I'm looking to dump my 2006 MBP, this may be a good way to go.
No quad core - all parts are dual core 2.66GHz Intel Core i7 is the top cpu. The quads run at 1.6Ghz approx.
Here's Intels link http://ark.intel.com/Product.aspx?id=43560 it very easy to stay up to date now Apple is on Intel |
2010-2012 Mac Pros, Imacs, and Macbook Pros do multi-channel HDMI audio out! | nst7 | Post - Surround - Video | 3 | 07-15-2013 04:37 PM |
Slightly updated Macbook Pros Out Today | nst7 | Pro Tools 10 | 16 | 10-24-2011 10:04 AM |
New Macbook Pros out today--HDMI support | nst7 | Post - Surround - Video | 3 | 04-15-2010 05:13 AM |
New Macbook Pros out today! I5, I7! | nst7 | Pro Tools TDM Systems (Mac) | 14 | 04-13-2010 02:31 PM |
new macbook pros | therecordinghouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-08-2007 07:51 AM |
