is digidesign 003 compatible with latest protools 2020
hi people, is my 003 compatible with protools 2020?
Re: is digidesign 003 compatible with latest protools 2020
00x family driver support has ended long ago
I was using a digi002 with 2020 on windows 10 up until a while ago..
You need to install the legacy FireWire driver though.. I've a post somewhere here on how to do it.. |
What Mac OS? Unsupported/discontinued doesn’t mean not working. I just set up a friend’s iMac with 10.13.6 and PT2020.12 with his 003R. Works perfectly. Technically, the 003 is unsupported on that Mac OS. I think 10.12 is the last version, but I’d have to double check. Regardless, it works fine. I tried a 003 for a colleague on 10.14 on a 2018 Mac Mini and that was a no go. Sent from my iPhone using Tapatalk |
The 003 is Firewire 400 only isn't it? That'll have to go into the equation.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
As alluded to in other posts - need more information on your computer.
There won't be an issue with running the 003 with PT2020, as long as there are drivers for the OS you're using. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
That’s not an issue. FW400-FW800 cable works fine. If the machine is TB only, add the required adapter/s. Again, the version of Mac OS installed is the main issue. Sent from my iPhone using Tapatalk |
Not really sure the OP is on Mac..
It would be best if we could get the following information: http://duc.avid.com/showthread.php?t=300050 Joel
His profile states Mac but I’m sure it’s out of date. I just assumed he was on a newer Mac setup.
But yes, again, some info would help. Sent from my iPhone using Tapatalk |
2020.12 not compatible with some plugins | itsthemusic | Pro Tools 2020 | 9 | 02-17-2021 06:25 AM |
Icon with latest 2020.9? | arche3 | ICON & C|24 | 7 | 09-18-2020 04:21 AM |
Latest Mac Compatible with PT7? | Aje82 | Pro Tools M-Powered (Mac) | 3 | 11-29-2013 08:25 PM |
Latest version of ProTools that is compatible with a Dual 2 GHz PowerPC G5 | M Brandon Dew | macOS | 4 | 03-25-2011 02:49 PM |
