Old 02-09-2011, 01:34 PM
changareth changareth is offline
Default Protools Lag Issue
I decided to move to PT9 from Logic and this is the error I get when I play my songs in PT9.
I only imported 5 stereo WAV files 16 bit 44.1khz and not running any plugins except 1 instrument track thats using BOOM for drums.
I tried increasing buffer size and all that but I think its just stupid coz if i increase to 1024 i will just get latency. So I'm just sticking to 512 thats the highest i'd go but then again I still get this lag and from time to time the increase buffer error. It's getting really annoying. Sometimes the track plays and when i hit space bar the song wont stop until like after 5 - 10 seconds of lag.
HOW CAN I FIX THIS? This is pretty bad. I use to run logic with gazillions of plugins and it worked just fine.
I am running an iMac duo core - Snow Leopard with 4GB of Ram and I PURPOSELY swapped back to a 7200RPM 2TB hard drive that I cloned off from my previous old HD that was 5200RPM. Although 5200 was running fine with logic I decided to switch it to 7200 for the sake of PT9. I use M-audio Firewire 410 interface.
I also tried not using my interface but I still have the same issue. I'm wondering if its my system itself that has a problem. should i do a fresh OS install instead of cloning from my 5200RPM HD?
I really dont see anything wrong with my spec it should be more than enough to run PT9. So how do I fix this god damn error???
Old 02-09-2011, 01:47 PM
daeron80 daeron80 is offline
Default Re: Protools Lag Issue
This is an external drive, right? You're not running the session off of your system drive?
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 02-09-2011, 02:13 PM
I tried both.
I tried running everything on my internal drive which is a 2TB 7200rpm HD. Problem persists.
I tried only running PT9 off my internal HD and audio files off external firewire HD which has a rate of 800mb/sec and problem still persists too..
I've pretty much tried everything I can think of. Just havent tried installing a fresh OSX without cloning my old hard drive.
Old 02-09-2011, 02:30 PM
You don't have to worry about latency if you're just mixing. That only applies to tracking. But with that computer you should have no problem with a hardware buffer of 64 in moderate size sessions.
What does "lag" mean?
David J. Finnamore
Old 02-09-2011, 02:53 PM
Well I do tracking and mixing too. anyways basically at any setting my protools response slowly. e.g. after i start playing the song when i wanna stop it i get like a 5-10second delay before it stops. Or when its playing and Im in another window and try to switch back to my PT window it delays too as if its frozen.
I basically cant accept myself working like that. And I believe it shouldnt even suppose to act this way.
Old 02-09-2011, 03:07 PM
formfunction formfunction is offline
What troubleshooting have you already done? Have you been thru the Troublshooting Sticky above? It is something in your system...ff
Old 02-09-2011, 06:34 PM
Go into Preferences and find the Record Allocation setting(which defaults to no limit). Set it for 15 minutes and see what happens.
[IMG] code is Off
M box 2 issue with protools LotusEater Windows 8 12-22-2014 06:52 AM
Protools 11 and MTC issue syra macOS 3 12-06-2013 09:39 AM
Protools 8 HD lag issue frankelmedico Pro Tools TDM Systems (Mac) 0 11-30-2010 11:43 AM
Protools issue or Mpc??? GProfit Pro Tools M-Powered (Mac) 0 12-23-2009 10:33 PM
Protools LE 8 Issue Phantom48 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-20-2009 06:03 PM
