Audio input reference levels?
I have a 96i I/O & a 96 I/O.
On the 96 I/O has +4dBu or -10dBV inputs, which do I use? and the same question for the audio outs? On the 96i I/O Inputs 1-4 have either +4dBu or -4bBV to -12dBV settings. Inputs 5-16 it's either +4dBu or -8 dBV, which do I use? I only have Synths plugged into each input & 1 output that goes back into a synth to be processed. 1more thing, Output Line levels going to my monitor speakers? +4 dBu or -10 dBV?
MacPro 2x3GHz Quad-Core Intel Xeon, SL 10.7.2, PT HD 10, Avid HD I/O & PRE, M-Audio Axiom Pro 49, MOTU MIDi Express 128, & many synths. |
Re: Audio input reference levels?
The specs for all of your synths should list an 'optimal' output level, as well as input, i.e. maximum output level =0dBu. If that's the case, keep everything at -10. +4 is really more for balanced high-output circuits that can push as much as +20dBu.
The same would hold true for your powered monitors and could be figured out depending on what type of input connector they have. If they have balanced XLR or TRS, then chances are +4 is what they want to see. If it's an unbalanced input, i.e. 1/4" TS or Phono jack, then you'll need to use -10.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
M-Audio Firewire Series Input Levels | danika | Pro Tools M-Powered (Win) | 3 | 06-30-2009 10:38 AM |
Audio Reference levels in a digital workflow | ChattyJ | Post - Surround - Video | 2 | 02-20-2008 08:21 AM |
Visual input levels but no audio | Burton... | Post - Surround - Video | 2 | 02-17-2005 01:38 AM |
Calibration/Reference levels | Mark Wheaton | Pro Tools TDM Systems (Mac) | 8 | 10-03-2001 10:36 AM |
reference levels in audio post for video | babyseal | Tips & Tricks | 11 | 02-27-2000 03:48 PM |
