Arturia Moog Modular in ProTools LE
I have upgaded to Protools 7.4 and am trying to use Arturia's Moog Moduar V 2.2. When I press the virtual keyboard the virtual key moves. This also works with my conroller keyboard. The white boxes at the top of the window for in and out I can select my keyboard for in but the out section only indicates SounMax. I cannot tet any sound from the programme both as a standalone and as a plug in. Should I be able to select the Mbox 2 or my audio interface? I can also select my audio interace which s a MOTU 128 express in the lefthand window .
I am using Windows XP. The programme worked before I upgraded to 4.7 so somewhere along the line I may not be setting someting up correctly Any clues Thanks Wellies |
Re: Arturia Moog Modular in ProTools LE
Try reinstalling MM2 and launch in Standalone mode, you should get a Setup Preferences options, select ASIO - ASIO Mbox. In Pro Tools make sure you have a valid Input selected for the Audio Input selector of the Instrument track.
filosofem
Aaron Mulqueen - 001 HD Native |
Hi Tried this and worked fist time -- briliant
Thanks so much for the help and tking th time to answer Wellies |
Arturia Moog Modular | Ron Fairchild | Virtual Instruments | 0 | 05-30-2007 05:25 PM |
Arturia Moog Modular update/new version | tvent | Pro Tools TDM Systems (Mac) | 8 | 08-28-2004 12:50 AM |
Moog Modular and ProTools | sequence025 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-03-2004 12:12 AM |
Getting Arturia Moog Modular V to work with PT | Carl Fuehrer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-25-2004 08:35 AM |
Arturia Moog Modular V 7204 error | Jim Cowgill | Pro Tools TDM Systems (Mac) | 0 | 05-03-2003 07:43 AM |
