newb:audio input + firewire = silence
Hi all,
I'm new here, and just picked up my MBox 2 Pro today. I've gone through the "Getting Started" guide and surfed these forums for about an hour without luck. My problem is that DI audio (a guitar in this case) produces no audio out. What's weird is if I disconnect the firewire, then it works. Reconnect it - no love again. I listened to the sample session that ships with PT and it worked fine (with the firewire connected, obviously). I know the guitar signal is reaching the MBox because the clipping light turns red. Am I missing something obvious? Is it firewire incompatibility? Any advice greatly appreciated. My config (homebuilt): WinXP Pro SP2 ASUS A8N32-SLI Deluxe Athlon X2 4800+ 2 Gig RAM Cool & Quiet disabled AVG anti-virus (any known probs here?) Silverstone 600W PS Thanks, Randy |
Re: newb:audio input + firewire = silence
we'll start basic and work up:
have you record enabled a track? What is the input set to on the track you're trying to get signal to? If you plug the DI into pre 1, make sure the track is set to analog 1. Make sure your track is either bussed to A 1-2 or routed to other auxes that end up going to A 1-2...hope that makes sense, its late and sounded better in my head
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
Thanks! My I/O didn't even have analog ins listed. Hitting the defaults button made everything show up. Kind of odd. This is a fresh install - it seems to me that the defaults would be, well, the defaults when you first install.
Anyhoo, all is well. Thanks so much. Randy |
Mic with XLR input recording slowly dies out M-audio firewire 410 with PT 8 | Menprivin | Tips & Tricks | 1 | 06-03-2012 09:35 PM |
PTLE 8.0.4 recording/metering problem (input mon. playback fine, but records silence) | blast9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-17-2010 08:45 AM |
Newb needs FireWire drive advice. | r0bertbr1an | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-07-2009 06:23 AM |
M-Audio Firewire Series Input Levels | danika | Pro Tools M-Powered (Win) | 3 | 06-30-2009 10:38 AM |
Anyone Tried MOTU 828 FireWire Audio Input? | smashannon | Pro Tools TDM Systems (Mac) | 2 | 04-05-2001 04:43 PM |
