Visual input levels but no audio
I'm not sure if this a 5.1 issue.
I've been using 5.1 for six years or so, much of the time without any problems. I recently reseated the main cards of a mix plus system to fit a serial midi port. I rebooted protools and now have track 1+2 with constant input levels but no audio. Does anybody have any ideas what is happening, I have run a digi test, all seems to be ok with the test but still the same 2 green lines of input level but audio. Exasperated... |
Re: Visual input levels but no audio
Is this an 888|24?
When you record arm do you hear audio? I had an issue with an 888|24 with spontaneous input signal. Digi dealt with it. I slipped under the wrnty. I'd also check my I/O settings just to dbl check too. |
This might be it:
From memory if your clock source is set to S/PDIF (session setup) and there is no digital signal present you will see levels but no hear any output. Cheers Mark
Mark Franken, MPSE Dialogue editor/supervisor IMDb Creator of 'EDI' applications for sound post editors www.soundsinsync.com |
Audio Editing for the visual guys... | danander11 | General Discussion | 2 | 06-26-2011 05:21 PM |
Audio input reference levels? | PostHuman | Pro Tools TDM Systems (Mac) | 1 | 06-08-2010 11:20 AM |
M-Audio Firewire Series Input Levels | danika | Pro Tools M-Powered (Win) | 3 | 06-30-2009 10:38 AM |
DigiTechSupport: Visual and audio "hangs". | The Dubnicks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 12-28-2005 10:04 AM |
visual display of audio information | Percustard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-28-2004 09:36 PM |
