Old 04-01-2013, 02:15 PM
sinewavz sinewavz is offline
Default AAX / AAX DSP insert order
Hello,
Does the rule of having RTAS first then TDM still applies with AAX / AAX DSP plugins ?
Thank you.
Old 04-01-2013, 04:55 PM
Chief Technician Chief Technician is offline
Thumbs up Re: AAX / AAX DSP insert order
I believe it does, though the hit on your voice count is only 1 voice per channel and not 2 voices. When you go TDM-->RTAS-->TDM on a mono signal path, you lose 2 voices going into RTAS and 2 voices coming out of RTAS. With HDX, you only lose 1 voice going into Native and 1 voice coming out of Native.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 04-02-2013, 02:15 AM
Default Re: AAX / AAX DSP insert order
so also the same with latency I presume ?
on old RTAS/TDM system, it also resulted in significant latency increase.
Old 04-02-2013, 04:45 AM
Drew Mazurek's Avatar
Twice the buffer I presume as it has to leave the card and come back. So if your computer is powerful enough, you can minimize this by setting the buffer as low as possible.
www.drewmazurek.com
Old 04-02-2013, 10:28 AM
JFreak JFreak is online now
Can't beat the laws of physics. It is either CPU or DSP who processes the signal, and if you switch between the platforms you will have latency issues sooner or later.
Old 04-14-2016, 05:45 PM
MixerGuy MixerGuy is offline
right, but if I have delay compensation on, (maximum) and nothing is going red..... then why is there a problem going DSP plug -> native plug -> DSP plugin?
ProTools HD10 with HDX-2.
audio tracks only.
Old 04-14-2016, 11:23 PM
The problem is, it takes CPU cycles to bring the audio into and out of DSP so if you have lots of traffic between DSP and CPU, eventually there is going to be a CPU spike that stops recording or playback
Old 04-14-2016, 11:44 PM
TOM@METRO's Avatar
And, The risk of 91xx errors goes higher.
And it's usually best to use only DSP plug-ins on record enabled tracks.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
HTML code is On
Plug-In Insert Order guatamas Pro Tools 10 3 03-16-2013 04:50 AM
Order region list in the order the regions are on a track Wesselink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-30-2009 06:53 PM
Insert order for vocal plugs? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-30-2007 04:13 PM
insert plugin order 4times4mil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-13-2006 03:22 PM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 05:45 PM
