dae 7204 and 7077 errors
I can't get bx digital v2 and puigtec tdm versions to run on my system, i get the not enough free dsp error, even on a session without any other plugins not even one instance of these plugins will run. I think i remember reading that certain tdm plugs are eccel only, could that be the problem? Any suggestions greatly appreciated. My system:
HD 1 pci 192 io windows 7 home x64 pt hd 9.0.2 (tried updating to 9.0.6 but wouldn't find hardware) i7 4770k can post sandra if needed |
Re: dae 7204 and 7077 errors
Good plan. Can't tell you much without it. |
Ok heres the SR. I'll also try updating to 9.0.5. When installed 9.0.6 it won't locate hardware both times i tried. Thanks!
SiSoftware Sandra ID Host Name : Shane-PC Workgroup : WORKGROUP Computer Model : ASUS All Series ASUS MB Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS Z87-PLUS Serial Number : 1304108******** BIOS : AMI (OEM) 0801 04/19/2013 Intel vPro : 9.00.02.1345 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (4C 8T 4.3GHz, 4.3GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1150 Chipset Memory Controller : ASUS Core (Haswell) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.87GHz 128-bit Memory Module(s) Memory Module : G.Skill F3-1866C9-8GSR 8GB DIMM DDR3 PC3-14900U DDR3-1866 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-1866C9-8GSR 8GB DIMM DDR3 PC3-14900U DDR3-1866 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : LG 27EA63 (1920x1080, 33.3") Monitor/Panel : LG 27EA33 (1920x1080, 33.2") Monitor/Panel : LG 27EA33 (1920x1080, 33.2") Video Adapter : AMD Radeon HD 7900 Series (32CU 2048SP SM5.0 950MHz/1GHz, 3GB DDR5 5.7GHz 384-bit, PCIe 3.00 x16) Graphics Processor OpenCL GP Processor : AMD Radeon HD 7900 Series (2048SP 32C 950MHz/1GHz, 3GB DDR5 5.7GHz 384-bit) Compute Shader Processor : AMD Radeon HD 7900 Series (2048SP 32C 950MHz/1GHz, 3GB DDR5 5.7GHz 384-bit) Storage Devices Seagate ST500DM002-1BD142 (500.1GB, SATA600, 7200rpm, 16MB Cache) : 466GB (F:) Seagate ST500DM002-1BD142 (500.1GB, SATA600, 7200rpm, 16MB Cache) : 466GB (F:) WDC WD1001FALS-00Y6A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (E:) Samsung SSD 840 PRO Series (256GB, SATA600, SSD) : 238GB (C:) ASUS DRW-24B3ST c (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices New Volume (E:) : 932GB (NTFS) @ WDC WD1001FALS-00Y6A0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) System Reserved : 100MB (NTFS) Hard Disk (C:) : 238GB (NTFS) @ Samsung SSD 840 PRO Series (256GB, SATA600, SSD) New Volume (F:) : 932GB (NTFS) @ 2x Seagate ST500DM002-1BD142 (500.1GB, RAID/SATA600, 7200rpm, 16MB Cache) Optical Drive (D:) : N/A @ ASUS DRW-24B3ST c (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS Lynx Point LPC Controller LPC Legacy Controller 1 : T0 C8-03 Audio Device : ASUS Lynx Point HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : PC Partner Tahiti XT HDMI Audio [Radeon HD 7970 Series] Serial Port(s) : 1 Disk Controller : ASUS Lynx Point 6-Port SATA AHCI Controller Disk Controller : ASUS Asmedia 106x SATA Controller USB Controller 1 : ASUS Lynx Point USB xHCI Host Controller USB Controller 2 : ASUS Lynx Point USB Enhanced Host Controller #2 USB Controller 3 : ASUS Lynx Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) Ethernet Connection I217-V (Ethernet) Wireless Adapter : Linksys WUSB6300 (802.11n (HT), AES-CCMP, 130Mbps) Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 7.7 |
i got 9.0.5 running but i still can't run bx digital or puig tec in tdm. All my other tdm plugs still work.
should i try updating to 9.0.6 again?
Have you made sure you have the latest updates of the plugins as that can sometimes screw with your system.
I would also try and update But make sure you have a back-up should something else happen to the setup. Best Regards Chris
bx digital is version 2.5.1
puigtec is version v9r14 |
Have you tried trashing preferences and Plist for Digidesign and Avid and let PT rescan all the plugins as I have never experienced this myself
i just updated bx digi to version 2.6, still no luck
No I have never done this before. I will try to figure out how to do this then report back, wont get a chance to do it til tomorrow morning. Thanks for help |
Help...... Still Getting -7204 errors | Jeremy Mix3000 | Pro Tools TDM Systems (Mac) | 5 | 12-07-2006 03:32 PM |
#7204 errors on HTDM plug-ins | bixpender | Pro Tools TDM Systems (Mac) | 3 | 08-22-2005 01:25 PM |
PLEASE HELP!!!!!!DSP ERROR -7077 | Micheal | Pro Tools TDM Systems (Mac) | 3 | 08-17-2005 04:33 PM |
DSP ERROR -7077 | Micheal | Pro Tools TDM Systems (Mac) | 4 | 08-14-2005 05:51 PM |
6.4.1: Error 7204 & 7077 With TDM plugs | Mount Royal | Pro Tools TDM Systems (Mac) | 1 | 12-07-2004 05:55 PM |
