syncing external drum machine
Greetings,
I'm trying to record midi tracks from a Zoom drum machine into pro tools 5.2 and can't figure out how to get PT to be the slave to the drum machine. I've searched the forum and didn't find anything relevant. Thanks, Marty |
Re: syncing external drum machine
You need to slave your zoom to PT. Just make sure you OMS is setup, that you have your zoom in that OMS setup, make sure your midi in's and out's are connected properly. Then you need enable Midi Beat Clock in Protools, you should be good to go. When you hit play in prtools you zoom should start playback in sync. Hope that helps
PowerMac G4/1.2ghzPowerLogix Panther OSx 10.3.4 Digi002/Protools 6.4/DVtoolkit Certified Protools6.x Post-Production Operator |
BTW you might need to set your drum machine to extrenal sync mode or something, "Local Control" check your zooms manual about sync to an external sequencer (PT's) Cool?
Tkank you
Marty |
Hi I had my roland r8 working synced in pt 11 w/7 & all of a sudden it began to change temo. where in pt 11 is the correct place to set the tempo. If I want to chose from 3 virtual rythim machines & 2 or 3 external i just change midi channels but temp is erratic. thanks have a good #1
Thank you Eddie & Marty. will give it a try. Good day
jc |
syncing external drum machine | yorgo | Pro Tools 9 | 2 | 02-25-2014 02:30 PM |
Trouble Syncing Drum Machine with Pro Tools | scottrolfs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-24-2014 06:49 PM |
Syncing Drum Machine to Pro Tools | cletus | MIDI | 2 | 01-04-2006 07:52 AM |
Syncing drum machine to PT? | Animal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-04-2005 12:05 PM |
questions with syncing up my boss drum machine | johnnymojo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-02-2004 02:47 PM |
