changing multiple outputs
all my outputs are normally set to 1 and 2 but now when i'm mixing on another system i will need to use s/pdif out and when i record i will need to switch back to output 1 and 2.
i have about 40 something tracks. how do i change them all at once back and forth?
mac pro dual 2.66, 9 gigs ram 10.5.6 macbook pro 2.4 ,4 gigs ram 10.5.6 Digi 003+ (BLA SIG MOD) FOCUSRITE 828 VINTECH X73 PTLE 8 |
Re: changing multiple outputs
hold alt and select
just realized i was on the mac forum, it may be a diff modifier
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4 32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE |
might be the command key then.
just might be a blessing for me that you were on the wrong forum...lol
hold ctrl while selecting output will give you multiple outs.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
thanks dism.
i assume it will change only the ones that are highlighted?
select all your tracks you want to change the output of (click first track, hold down shift, select last track)
hold opt + shift and change the output on one track, this will change all selected tracks also works for inserts, sends, inputs, and outputs
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
Go to the I/O setup and just drag the existing outputs to where you want them.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
beautiful!! thanks barstool.
guys.
Changing multiple inputs/outputs at once? | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-25-2010 07:25 PM |
changing inputs/outputs on multiple tracks? | bigboi78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-13-2007 07:54 AM |
Multiple outputs for multiple players. | KingFish | ICON & C|24 | 1 | 05-08-2004 01:13 PM |
Changing multiple outputs at once... | El CaCa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-22-2004 01:19 PM |
changing multiple outputs | Ricco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-16-2002 12:25 AM |
