Mbox2 mini interference noise & Pro Tools recording two lines
Hi there,
I have just bought a Mbox 2 mini and Pro Tools LE in January this year and I am new to it as well as the idea of recording itself, so please bear with me... Everything was working fine until a few days ago, when it started to make some unpleasant interference noise. The noise is so loud and when I arm a track and press record without connecting anything to the Mbox mini, it records on two lines. To monitor the sound, I use a pair of headphones connected to the front of the Mbox mini. I started to be aware of the problem the last time I used a microphone. I connected a cheap dynamic mic (which would not record without phantom power so I kept 48V phantom power button at the back on) to Mbox mini using an XLR cable. Then when I finished with it, I turned off the mic first then disconnected the cable from Mbox mini, then I started to be aware of this problem. The model of the dynamic mic is Yoga DM-330B. I guess this might be an audio interface problem rather than my computer. Turning the Input 1 knob right up on the front of the Mbox mini aggravates the noise. Turning the Input 2 knob does not make any difference. My settings (via SiSoftware Sandra): -------------------------------------------------------------------------- Computer Model : Asus A7Sv Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM)2 Duo CPU T7500 @ 2.20GHz Speed : 2.2GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Platform Compliance : Intel Centrino Duo Mobile Technology Mainboard : Asus A7Sv BIOS : AMI 203 07/26/2007 Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DDR2 SO-DIMM Chipset Model : ASUS Mobile PM965/GM965/GL960 Express Processor to DRAM Controller Front Side Bus Speed : 4x 199MHz (796MHz) Total Memory : 2GB DDR2 SO-DIMM Memory Bus Speed : 2x 332MHz (664MHz) Video System Video Adapter : NVIDIA GeForce 8600M GS (16 SM4.0 1.1GHz, 256MB DDR3 2x704MHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 8600M GS (16SP 2C 1GHz, 256MB 2x704MHz) Adapter : NVIDIA GeForce 8600M GS (16SP 2C 1GHz, 256MB 2x704MHz) Storage Devices FUJITSU MHX2250BT (250GB, SATA150, 2.5", 4200rpm, NCQ, 8MB Cache) : 233GB (C:) (D:) (F:) HL-DT-ST DVDRAM GSA-T20L (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices VistaENG (C:) : 87GB (NTFS) @ FUJITSU MHX2250BT (250GB, SATA150, 2.5", 4200rpm, NCQ, 8MB Cache) VistaJP (D:) : 29GB (NTFS) @ FUJITSU MHX2250BT (250GB, SATA150, 2.5", 4200rpm, NCQ, 8MB Cache) DATA (F:) : 110GB (NTFS) @ FUJITSU MHX2250BT (250GB, SATA150, 2.5", 4200rpm, NCQ, 8MB Cache) Optical Drive (G:) : N/A @ HL-DT-ST DVDRAM GSA-T20L (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS ICH8M-E (ICH8) LPC Interface Controller Audio Device : ASUS 82801H (ICH8) HD Audio Controller Audio Codec : Realtek Semiconductor High Definition Audio Audio Codec : Silicon Laboratories Motorola SM56 Speakerphone Modem Serial Port(s) : 1 Disk Controller : ASUS 82801H (ICH8) Ultra ATA Storage Controllers Disk Controller : ASUS Mobile SATA AHCI Controller Disk Controller : ASUS JMicron 20360/20363 AHCI Controller USB Controller 1 : ASUS 82801H (ICH8) USB UHCI #4 USB Controller 2 : ASUS 82801H (ICH8) USB UHCI #5 USB Controller 3 : ASUS 82801H (ICH8) USB2 EHCI #2 USB Controller 4 : ASUS 82801H (ICH8) USB UHCI #1 USB Controller 5 : ASUS 82801H (ICH8) USB UHCI #2 USB Controller 6 : ASUS 82801H (ICH8) USB UHCI #3 USB Controller 7 : ASUS 82801H (ICH8) USB2 EHCI #1 FireWire/1394 Controller 1 : ASUS R5C832 IEEE-1394 Controller Printers and Faxes Printer : Visage PDF (1440x1440, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : hp psc 1200 series (1200x1200, USB, Colour) Scanners and Cameras Scanner : Hewlett-Packard HP psc 1200 (Scanner, USB) Network Services Network Adapter : Attansic L1 Gigabit Ethernet 10/100/1000Base-T Controller Wireless Adapter 1 : Intel(R) Wireless WiFi Link 4965AGN (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows Vista Home 6.00.6001 (Service Pack 1) Platform Compliance : x86 Windows Experience Index Current System : 4.3 -------------------------------------------------------------------------- This is the noise I get: http://dl.dropbox.com/u/1691971/Noise.R.wav And the screenshot of the two lines: http://dl.dropbox.com/u/1691971/Noise%202.jpg And the screenshot of how this noise is recorded into Pro Tools: http://dl.dropbox.com/u/1691971/Noise.jpg What I have tried so far are (none of which worked): - Used different USB cable - Used different USB port - Disconnected the laptop from the power supply - Disabled Wifi Any help is appreciated, as I can't do any decent recording until I solve this problem! Many thanks Itsuka |
Re: Mbox2 mini interference noise & Pro Tools recording two lines
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Yeah I've thought dynamic mics didn't need phantom power but I tested recording without phantom power button on for this mic and for some reason it would not record. As you say, supplying phantom power to mics that don't require it should not damage the interface, while it might damage the mic... Cheers Itsuka |
I see you only have one hard drive. This won't cause the problems you're describing, but it is going to give you a lot of buffer errors. You need to procure a dedicated 7200-rpm drive for your sessions. And typically phantom power will NOT damage a dynamic mic.
This is only the second time I've seen this two line thing. The other was maybe a month ago and I don't remember a resolution short of a total reinstall.
I will sort out a dedicated hard drive... once I solve this problem! Cheers Itsuka |
I think I should try a total reinstall if I can't find a solution for this noise... Cheers Itsuka |
OK, still haven't heard back from Avid Knowledgebase people but I've contacted Digidesign Japan support (to which they responded the next day).
I didn't register the product in Japan so understandably I am not entitled to their customer support but they did mention that the two lines seem to be caused by DC offset. By Googling, I kind of got some idea that something is interrupting to cause the waveform mean amplitude not to be zero when silent. I can hear the noise from the Mbox2 Mini when Pro Tools is not open, so again I guess this is the audio interface problem rather than the software. I have also narrowed it down to the fact that this is the only case with Input1. When I set the input of a mono track to Input2, it is fine. http://dl.dropbox.com/u/1691971/Wave...Screenshot.jpg I am kicking myself for not learning science seriously in highschool but just wondering if there is anyone who has got any idea regarding the cause of this... Nothing is more frustrating than when you start out to write, play, record music but you spend a lot more time sorting out technical problems! |
Recording Kurzweil PC3x with Mbox2 Mini: noise problem (possibly ground loop) | terhardp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-13-2011 03:29 AM |
Digital Noise Blips on LE Mbox2 Mini | hotgravy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-29-2010 04:02 PM |
Grasp-vinyl noise on Mbox2 MINI | jollyboss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-11-2010 04:59 AM |
Protools le 8.0 Mbox mini interference and two lines wavelength | ineedanswers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-14-2010 05:09 PM |
MBOX2 Mini Hum/White Noise?!?! | MPRO82 | Pro Tools M-Powered (Mac) | 1 | 02-28-2008 04:41 PM |
